Question about Vizio P50HDTV20A 50 in. Plasma HDTV
Sides of my Vizio distorts images and makes them big. If a mans arm is there it will be 3 times larger than the other that is farther in the screen. I have a VP50 HDTV 20A
  • 597 Answers
The problems most likely could be as a result of a bad lamp. Have that lamp replaced and the television will be in good condition again.
Another fault could be that there might be a component that is faulty on the main panel of the television like a cold joint which is that lead from a part might have melted on another part causing a bridge. This can be corrected by having a repairman use a soldering iron to melt off the bridged lead.
Take care and good luck.
Posted on Oct 11, 2010
  • Rob Donnelly Nov 09, 2010
    I have the same tv. Did you check to make sure it wasn't set on panoramic mode ? If it is, It distorts just the edges of your screen on the left and right. Leaving the middle without distortion. Just a thought.
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Vizio TV has purple haze and colored stripes on the sides of the picture.
You possibly have a failing hi-voltage module or fly-back transformer going bad. If it has a fly-back transformer, It's not worth the trouble. Some repair shops will sell you a module. Call a repair shop for help.
May 09, 2017 | Vizio Televison & Video
The screen on our 42"
  • Turn on your VIZIO HDTV. Press the orange button with the "VIZIO" logo, which looks like a letter "V" with a triangular wedge in the center. If there is no VIZIO logo button, press the "Menu" button. Press the "Right Arrow" button twice to highlight the "Setup" icon, which looks like a wrench.
  • 4
    Press the "Down Arrow" button three times to highlight the "Wide" menu item. Press the "Left Arrow" or "Right Arrow" buttons repeatedly until the correct aspect ratio is selected. "Normal" is for a standard definition 480i signal, which has a 3:4 aspect ratio. "Wide" is for high definition signals, and has a 16:9 aspect ratio. "Panoramic" stretches the outside of the image while keeping the center at the normal aspect ratio. "Zoom" enlarges the image on the screen. Press the "Last" button twice to close the VIZIO on-screen menu.
  • 5
    Watch the image on the screen of your VIZIO HDTV to ensure that the picture is at the right aspect ratio. If it still looks distorted, it's most likely because you chose the wrong aspect ratio setting, because your source device is set incorrectly or because you used the wrong connection method.
  • Feb 27, 2011 | Vizio VW42LF 42 in. LCD HDTV
    How to get an undistorted picture without cropping. This is an Olevia, and it is not listed below.
    I assume you have a wide screen tv? most TV show are broadcast in a square (4:3) format, on a wide screen television the screen is rectangular, so to fit the square picture on the rectangle screen you have to either crop the top and bottom, or stretch and distort the image. the only real solutions are either to watch everything in the 4:3 format (leaving the sides of your screen blank), or subscribe to HD which will broadcast most programs in a wide screen format with out distortion.
    Sep 14, 2010 | Televison & Video
    Vizio 32'' VO320E Image Distortion
    I hope not but:
    this is probably a failure from the screen or the electronic parts that control the videosignals.
    i think having a specialist or the tecnical service from vizio taking a look at it will be best and safest.
    Hope this is helpful, and greetings,
    Olivier.
    Oct 21, 2009 | Vizio VO320E LCD TV
    Flatron w2043s 20" there is distortion on all letters and numbers etc, its as if its ran out of ink ,spoils the picture big time
    The distortion mostly is caused by a wrong screen resolution. Choose another (smaller or larger) resolution and once you've found the correct resolution for your display card tne distortion will be gone.
    Aug 03, 2009 | Computers & Internet
    Why do we have black bars on top and bottom of screen
    Originally when 16:9 TVs were produced movies were being shot in 16:9 so that you had a full screen. Now they are being shot in 14:9 as it gives you a more cinematic experience. This is due to the fact that colours look more vibrant when they are placed against a colourless/lightless surface (such as a black panel) as for the bars on the side of the screen LuciferStarr is correct; it depends on the format in which the video was originally produced. For example most older television shows are still shown in 4:3 but newer shows and movies are produced in the widescreen format.
    Jun 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Picture is distorted from center on my 65
    You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
    May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
    Picture is distorted from center on my 65" Sony projection TV.
    hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
    CLICK HERE
    May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
    Vizio VX32L image distorts on edges like looking in a metal bowl.
    I had a similar issue. Realized that the TV's "WIDE" setting was changed from "Wide" to "Panaramic". It was this panaramic setting that was causing the distortion on both sides of the screen. I had to switch it back to "Wide" using the "Wide" button on the remote to toggle back to "Wide" setting. Once I put it back to "Wide", problem went away. Hope this helps.
    Jan 12, 2009 | Vizio L32 32 in. LCD HDTV
    Vizio P50HDTV20A 50 in. Plasma HDTV Logo
    60 people viewed this question
    Top Vizio Televison & Video Experts
    CoppellTVRepair.com
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
