Question about Dell E196FP 19" LCD Monitor
Position of monitor
I need to move the monitor down. I work on a table on it is situated too high. Not tilt, but actually the monitor itself needs to be lowered.
  • 3,940 Answers
There is no mechanism on the stand to raise or lower the monitor.
Aside from removing the stand an setting the monitor on the table leaning against something or machining a shorter stand, there is no way of lowering the e196fp display
Posted on Jan 25, 2009
Stand monitor
The monitor should be able to move up and down and tilt from its stand. You can try this by grabbing the sides of the monitor and rotating it inward or outward. It should not take much effort to get it to tilt. If it doesn't move with minimal effort then it may not be able to tilt.
Oct 14, 2013 | Acer Aspire 5600U all-in-one desktop
How do I adjust the tilt function. It seems it is stuck
Tilting on most Monitors is designed to require some force to prevent it from slipping.
Gently yet firmly hold down the base of the monitor on the desk with one hand. Then place a second hand on the bottom of the screen and pull it towards you using even pressure. It will slowly move.
Please also keep in mind that your monitor may not be able to tilt much. If you need it to tilt further, you can buy an alternative stand for it.
Apr 07, 2011 | Samsung SyncMaster 740BX Monitor
Monitor facing ceiling want it to face me sitting upright
mcdevito75 here, You should be able to hold the monitor at the 9 and 3 O"clock position and simply use your hands to tilt the monitor to it"s desired position, look for any Locking type knobs on the back of the monitor Not the monitor itself but the base, the part the monitor is attached to, if so Loosen knob--s just enough to move monitor then re-tighten when done.
Jun 25, 2010 | HP L1950 LCD Monitor
I have a 23" LG monitor W2343T PF. I have taken off the oval base, but I need to get rid of the stump that connects the monitor itself to the oval base that sits on the table. I have been to two Best Buy...
I have checked with LG and unfortunately there is no option of taking out the stump as the monito was meant to be kept on the table over the stand which came along with it.
Bur we do have a option of all mounting the monitor as well for which you will have to separately purchase the wall mount plate.
Please call the customer services at 1300 54 2273.
According to your monitor size, you should choose the right mount fits your monitor size. Also pay attention to the mount max loading weight.
The wall mounts have various kinds of format. Such as tilt mount format, flat mount format, swivel/tilt format what you like to mount it.
You can visit the professional monitor mount store www.mount4less.com.
Feb 18, 2010 | LG Computers & Internet
Tilting Problem with monitor
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Jun 06, 2009 | Acer 22" X223w LCD Monitor
Monitor Pivot won't turn for the monitor to tilt
If it is crt monitor rotate and tilt up or down. If it is Lcd just push to move front or back.There is nothing to be loosen.
May 04, 2009 | Computers & Internet
How to angle the monitor
I have Model X203H & had the same problem. The support CD explained how to adjust the monitor:
Apr 16, 2009 | Acer 22" X223w LCD Monitor
Acer 5920 screen black out
If movement is affecting performance of a device, most possible chances are you have a loose connection. Please contact the vendor for a replacement of the LCD cable / the LCD itself as the case might be
Jan 11, 2009 | Computers & Internet
Screen tiled and i can't move it back
Try reseting the settings to factory defauts in the monitors user menu. You can get more details from the manual on this.
If reseting the settings doesnt work. Could you take a photo so we would have a better understanding of the problem :-)
Or do you mean the screen is fysically tilted? If parts are broken and you are unable to move the screen, then I cant offer much help, you could contact acer for support or to take it to a local pc shop for analysis.
Feb 08, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Dell E196FP 19" LCD Monitor Logo
144 people viewed this question
Alun Cox
