Question about Google Chrome
How to attache to my face on the photo different clothes
    Problem Solver:
  • 23 Answers
Please solve the victim software counterfieting
Posted on Oct 11, 2010
The ink cartridges do not move when i open the printer lid
We have just re attached the encoder strip after it came off. We now are faced with the ink cartridges not moving when we turn the printer on even though the belt is moving
Oct 04, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Scan doc on epson to send email
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
you can send an attachment to a company by an email
open up your new email type in the adress then you should see attachment depending on which email you are using select attachment then you will open up a browse window navigate to your document/attachment select it you might have to wait a few seconds for it to load as an attachment then click send
hope this helps you
Feb 17, 2012 | Epson NX200/SX200/TX200
I have a pic of me on face book need to send it in an email dont no wot to do
you can send photos to a another email adress by an email
open up your new email type in the company adress then you should see attachment depending on which email you are using select attachment then this will open up a browse window navigate to your photo/s select your photos you might have to wait a few seconds for it to load as an attachment then click send
if you need more help with this post a reply
hope this helps you
Aug 18, 2011 | Computers & Internet
I have a Canon printer and want to learn how to do scanning on it so that I can send things to friends.
hope this helps
Aug 09, 2011 | Computers & Internet
I have a Cannon Pixma mx330 printer.How do I scan a document and attach it to an email?
hope this helps
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Does not rotate to dry clothes hotpoint TVM560
The problem is likely the dryer belt . Go to www.appliancehelponline.com/servicemanual.html there is a video that will show you how to replace it. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. There are also videos on disassembling your style dryer.
Apr 09, 2010 | Washing Machines
Camera doesn't focus very well on dark subjects.
I think you have 2 problems at one time.
1 - I notice that your depth of field is very narrow, (your aperature is quite open) which hardly can focus the spot you want. try to increase the f/number like f/4 or above. the models face and there clothes toward your nikon D100 is almost the same distance, so they should be in the same focus range, but as I said witch big aperatures like f/2.8 of f/1.4 every inch count when it becames to focus.
2 - Set your camera in Single-focus (not Continous focus) en focus on the models face. then press halfway en keep it pressed. then you can compose a new position (still pressed halfway) and when the composition is good, then press it further to capture the photo.
Jul 02, 2009 | Opteka HD² for Nikon D80, D70s, D70, D50,...
Loose Door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Sorry, but I can't be more specific on non-US models.
Hope this helps!
Jun 17, 2008 | Neff B7740N0GB Microwave Oven
Google Chrome Logo
16 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
