I bought the thermaltake v9 Blacx the other day and the standoff screws that came with the case only seem to screw in a quarter of the way. Where can I get smaller standoff screws?
    Master:
  • 397 Answers
Generally, any PC enthusiast site will have what you require- I would honestly try the local Radioshack as well- invariably they have some of the smaller odds and ends for pc building and repair
Posted on Oct 11, 2010
Hello. I purchased the Thermaltake Blacx Duet-Dual Hard Drive Docking Station and am currently attempting to clone to 2 SATAs. How do I know when the cloning is complete?
Your doing a cloning of two large drives using a USB device as I have the same docking station. Cloning a 2TB drive will take some time depending on how much data and number of files on the drive being cloned. USB even 3.0 protocol is dog slow!
Give it time and do not interrupt the clone once started.
Dennis
Apr 14, 2017 | Thermaltake Computers & Internet
I need the instructions for Thermaltake BlacX ST0005U
The manufacturer page for this item is here: http://www.thermaltakeusa.com/products-model.aspx?id=C_00002058
Their support page does not provide a manual, instructions or drivers.
I suspect that is because none are needed. This is essentially an external hard drive enclosure for SATA drives which are standard. Connected via eSATA or USB.
Oct 21, 2014 | Thermaltake Computers & Internet
My windows 7 Home will not read my new Thermaltake BlacX Duet. Downloaded new driver and still no luck. Anyone have some suggestions? Im not a programmer, but can follow instructions. Thermaltake web
try with knowingly functionating hdd, also hdd sometimes will not display in my computer due to partition error, but will display in control panel- administrative tools - computer management - disk management , new hdd-s might do the same because they only have unallocated space,and need formating. I don't know if the device itself should display itself or not, check in device manager but maybe its normal that its invisible and shows only hdd-s. If a hard disk has malfunctioned to an extent, you will not see it anywhere in windows
hope this helps
Sep 17, 2014 | Thermaltake Blacx Duet St0014u 2xhd Sata...
How to connect blac x to sharp tv
Make sure there is a Windows formatted hard drive in the unit. Simply use one of the USB ports to attach the TV. Then navigate TV to USB input. That's it.
You need to make sure the TV has a USB, and verify media supported.
Oct 12, 2012 | Thermaltake Blacx Se HDD Dock with USB...
Driver for thermaltake blacx n0028usu
Go to the Thermaltake website and download from there.
Mar 14, 2012 | Thermaltake Blacx N0028usu Docking Station...
I have the Thermaltake BlacX 5G Dual hard drive docking station and I cannot get the hard drives to show up on my computer. I don't have USB 3 on my computer so I am using a regular USB 2.0 cable. I...
I know it might sound a bit simple, but let's start at the beginning.
Make sure that the power is properly plugged in, and that it's securely plugged into the USB port.
Put in the hard drive you will be using.
Now turn on your device by clicking on the power button.
Listen out for a "ding" or a chime in your OS.
If you DO hear one, the hard drives may need to be properly formatted or not properly assigned.
If you hear a chime, go to your desktop and right-click on "Computer" and click "Manage"
Go to "Disk Management" and at the top, there are a few options, and check for your hard drives, and right-click on the proper one and click on "Change Drive Letter and Paths" assign it a letter, and check "Computer" to see if came up.
Thanks,
Please Rate.
Jul 11, 2011 | Thermaltake Removable Storage St0019u...
How do you get an external sata disc mounted in a dock (Thermaltake Black X dock) to communicate with a WIN 98 SE system? The box says the dock supports WIN 98 buit I cannot find drivers that work.
Microsoft stopped supporting Windows 98 over two years ago,
and stopped supporting Windows 2000 on July 16, 2010.
So, any company that manufactures "new" (in the last two years) hardware probably will _NOT_ have written device-drivers for Windows 98/98SE/NT/2000.
Does the external disk work correctly when connected to a computer running Windows XP? Vista? 7 ?
If not, then maybe the external disk itself is the problem.
Sep 08, 2010 | Thermaltake Blacx Se HDD Dock with USB...
Swapping motherboard. I dont see any screws
Either case is very old or mobo is mis-matched, need to replace one of them.
Mar 29, 2010 | Compaq (283983-001) Motherboard
What size allen wrench do i need to tighten the door handle on model 6 bar, which is a smaller wine cooler? is it metric or standard?
It's been awhile since I looked at one of those. I do know it is standard and think it is a 5/32" but could be a 5/64". The set screws just hold the handle onto the standoffs. If the standoffs are loose, you will need to loosen both set screws, remove the handle, tighten the standoffs to the door using a phillips screwdriver and reinstalling the handle.
Feb 21, 2010 | Marvel Refrigerators
Powerswitch bay stuck!
you have to take the front of the case off. Every case is different, there may be clips you have to push in to release the front or there may be screws. once the front is off look for the power switch and glue it back into the switch slot. originally it was probably glued in with hot glue.
Aug 23, 2007 | Thermaltake Kandalf LCS VD4000BWS ATX Full...
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
