Question about Compaq A3000 All-In-One InkJet Printer
Removing old ink cartridges
How do i remove the old ink cartridges?
  • 148 Answers
If you go to this link http://support.radioshack.com/support_accessories/doc66/66491.pdf
You will find a copy of the operation manual for the Compaq a3000, on page 4 tells how to replace the cartridge...
With printer plugged in open small door in front, cartridges should move to a position that will let you remove them, pull the top of the cartridge first then the rest will come with it, just reverse this when installing the catridges...
Hope that helps
Posted on May 31, 2008
    Guru:
  • 1,342 Answers
Click HERE to download your User's Manual
How to remove ink from printer
Ink Cartridge Maintenance
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
How to instal a new printer ink cartridge
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
How to change the ink cartridge in a Canon iP1900 printer please
1•Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
•2
Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
•3
Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
•4
Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands.
Aug 18, 2010 | Canon Office Equipment & Supplies
How do I change the ink cartridges in my Canon MP480? rn_bluediamond@yahoo.com
Step 1
Step 2
Step 3
Step 4
Aug 11, 2010 | Canon Pixma MP480 All-In-One InkJet...
Cannon selphy es2 - how do i remove old cartridge?
you can remove the old ink cartridge from the Canon selphy es2 by simply lifting the small green lever on the ink cartridge carrier. Take note of how the cartridge was situated in the carrier, then gently take the old cartridge out of the printer.
Jan 18, 2010 | Canon Office Equipment & Supplies
How do I remove old ink from a phaser 8560? It is bargain ink (terrible) and we want to replace it with genuine Xerox.
You should be able to contact Xerox directly for information concerning ordering new ink cartridges As for removing existing cartridges, the lift hatch at the top of the unit allows access to the cartridges.
Aug 31, 2009 | Xerox Phaser 8560DN Laser Printer
Says ink tank level low when it is still half full.Then will say out and still lot of ink in cart left yet.
This usually happens when you are using aftermarket inks. The sensors on the cartridges are not always up to specs. The problem does not occur on OEM cartridges.
Sometimes you can remove and reseat the same cartridge and the printer will resume. If the problem persists after trying the remove and reseat procedure, the cartridge should be replaced and the defective cartridge discarded.
If you are near an office supply that rebates for old cartridges and you are reloading your own cartridges, take the old cartridge in and replace it with an OEM cartridge so the problem doesn't repeat.
Hope this helps.
Aug 10, 2009 | Canon PIXMA MX850 multifunction InkJet...
REMOVING OLD INK CARTRIDGE
Click on this link:
Z600 Series Manual
Go to page 42. There are detailed instructions for removal and replacement of your cartridges. (With pictures.) :-)
Thanks for using Fixya.
Jun 19, 2009 | Lexmark Z640 InkJet Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Compaq A3000 All-In-One InkJet Printer Logo
82 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
