Question about Konica Minolta Dimage Scan Elite 5400 II Film Scanner
Cannot insert holder into unit
The light insists on only blinking and the holder will not go in until the light is solid. I have tried the reset to no avail. The door is not opened, it is shut. Does anyone know how to remedy this?
  • 1 more comment
  • photo_lover Jun 02, 2008
    Thank you. I will try that,
  • rowantree633 Jul 31, 2008
    I have the same problem and running XP.
  • maxa919 Sep 29, 2008
    Windows XP. Native driver.
It all depends on your operating system. If it's Windows Vista there is only one solution and that's buy Vuescan. Konica minolta discontiued making these units. Sony has the product support rights, and are not inclined to provide a Vista driver for the product. My information is that Vuescan will work but I don't know any more than that
Posted on Jun 02, 2008
Password1752809
If you forgot your password and/or want to reset the router back to the default settings:
Step 1 Power the unit off by unplugging its power adapter.
Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure.
The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case). The default IP address is 192.168.0.1.
BEST OF LUCK
Dec 15, 2013 | D-Link DI-704P Router
Need to rest speedstream6520 admin password
Hello mattsss,
1. Turn the modem on. Wait until the modem has stopped booting up and the power light goes solid green.
2. Insert a small tipped object (pen tip or a pin will do) into the hole at the bottom of the modem labelled 'reset'. You may need to hold this in for a couple of seconds before the reset is initiated. You will know when to let go of the reset hole when the power light starts blinking red/green. Remove the small tipped object. All the lights on the front on the modem should flash green and then red then the modem should start to boot as per normal.
3. Once the power light is on solid the modem should be restored to factory defaults.
The default admin username is "admin" and defult password is "admin"
Feb 25, 2011 | Computers & Internet
Where is the toner cartridge and how do I find it?
Plug the Lexmark 2600 into an electrical outlet and press the power button. Allow the unit to power up. The power button will turn green when ready.
Turn on the Printer and Open the top cover of the Lexmark 2600 by lifting the cover upward. you will find all cartridges down there.
Now you see how to replace them
Remove the black ink cartridge from it's packaging. Remove the tape from the black ink cartridge first and place the cartridge into the left ink cartridge holder. Press the cartridge down into until you hear it lock into place. Close the ink cartridge holder lid by pressing it down firmly. This secures the ink cartridge in place.
Remove the colored ink cartridge from the packaging and remove the tape from the cartridge. Place the cartridge into the right cartridge holder and press down until it clicks into place. Push down the cartridge holder lid.
Close the lid of the Lexmark 2600 and allow the print cartridges to align. The power light will be blinking while the cartridges are being aligned; once the power light turns solid, the printer is ready for use.
Do rate, if found helpful
Nov 27, 2010 | Lexmark X2600 InkJet Printer
I have a digipower lithium power charger TC-U100 and cannot get my Casio NP-60 battery to charge in it. Am I inserting it wrong?
Maybe. This unit charges all different kinds of batteries, but that requires you to make sure that you have set the prongs in the right position to connect with the particular battery you are charging. You move two pins to align with the outer contacts on your battery (not the middle one) and then a spring door holds the battery against them. The unit sets the polarity automatically. 4 lights blink green until the battery is fully charged at 4 solid lights, i.e. 1 blinking light is a quarter charged.
Nov 22, 2010 | Mizco Digipower Lithium Ion Digital Camera...
Wireless light is not on
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot. If the wireless router fails to restart or the power light continues to blink or turns solid amber, the unit may be defective. If the error persists, you might have a hardware problem and should contact technical support.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Why does the drum light blink on my brother hl-2140
The blinking indicates that the drum unit is near the end of it's life. It will shut down soon and you will lose the ability to print until it is changed or reset.
To reset the drum counter. Press and hold down the white button (shown as blue in the image below) for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the button.
Nov 18, 2009 | Brother HL 2140 Laser Printer
I forgot my password. Can you assist?
In the worst case if u really do not remember your password, then the best way is to reset your router to it factory default configuration setting. To do this, you must use the Default Reset button on the rear panel of the router:
1) Press and hold the Default Reset button until the power light blinks on (about 10 seconds).
2) Release the Default Reset button and wait for the router to reboot.
If the router fails to restart or the power light continues to blink or turns solid amber, the unit
may be defective.
YBC (/\)
Oct 02, 2009 | NetGear MR814 Wireless Router
Factory setting
Step 1 Power the unit off by unplugging its power adapter. Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure. Step 3 Power the device back on by plugging it in. Continue to hold the reset button. Step 4 Watch the lights on the front of the router. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button. The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, unplug the power on the router and plug it back in. If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
Feb 16, 2006 | D-Link DI-704P Router
Factory settings
Feb 16, 2006 | D-Link DI-804HV - 4-Port Broadband VPN...
Konica Minolta Dimage Scan Elite 5400 II Film Scanner Logo
262 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
