Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
When we turn it on we cannot add credits to play the records. The box that tells you the credits is not lighting up.
  • 98 Answers
This sounds like a problem with your Selection and Credit Computer. I can fix this for you and even help troubleshoot to make sure that is the problem. Please email tech@wurlitzer-ohio.com and I'll email back my phone number.
Posted on Nov 04, 2010
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Www philips com support
This unit doesn't have a tuner of any sort. Even on the few DVR/DVD recorders that have tuners, the external composite video inputs do not connect to the tuner. To record from the L1 or L2 inputs, you must be using a set-top box (cable, satellite, or digital-to-analog converter for OTA signals) or another video source (video camera or a vcr). Most TVs do not have video output capabilities. If you have one of those, follow the directions for recording from set-top boxes below.
Turn on and set the source to the channel that you wish to record for any set-top box. Then make sure that the set-top box is left on and at the correct channel after you finish setting the frequency, speed and length of time for the recording. Note: if the set-top box is turned off, your recorder will still record the blank video and audio.
What source do you have connected to the VCR?
To record from a video camera or a VCR, set that source to play back at the desired time point. This is best done without the timer. Just start recording and then the playback.
I hope this helps. Please add a comment with your video source for more support.
(My OTA tuner has a energy-saver option that turns off the unit when there is no activity for a while. Since I usually record when I'm either asleep or away from home, I had to disable the feature to get the correct recordings.)
Jul 04, 2013 | Philips DVP3345VB/F7 DVD Player/VCR
I have A Wurlitzer OMT 1015 Vinly 45 RPM . Not able to make a selection from buttoms.The LED display does not light up and can not get any credit on the credit buttom. Is this a motherbroad problem?
Check the fuses behind the coverplate of the amp on the left. If it is a K99 it comes off by loosening the two nuts at the top then flexing it and popping the bottom edge off. If it is a Compact amp you can see the fuses.
Apr 02, 2012 | Wurlitzer Jukebox 1015 One More Time...
Jukebox lights work - when turned on the record carousel does not reset and the LED display does not work and records do not play
The problem could be the selection and credit computer or possibly the K7 switch actuator. I can repair the computer and I stock the K7 switch actuator. Please email tech@wurlitzer-ohio.com
Jan 12, 2011 | Wurlitzer Jukebox 1015 One More Time...
I have a wurlitzer super star juke box. the
I think I can clear things up for you. The free play switch you're referring to is just to add credits. If you want continuous free play, I sell you a jumper plug to bypass the credit unit, commonally called BOAC, if you have a 3600 series Super Star. Please email tech@wurlitzer-ohio.com.
Mar 11, 2010 | Wurlitzer Jukebox 1015 One More Time...
Hello i have a omt 1987 1015 lights power up but will not play when you select led shows record to be playing but does not play will not show credits or house hits have checked all fuses none blown have...
Is your 3 digit display on? If not, does the Z LED Flash when rotating the record carrier? If so, you may need to have your computer repaired. If the Z LED doesn't flash, check the 12 volt fuse in the amplifier. If you need your computer repaired or further assistance, please email me, Rod Stebelton, tech@wurlitzer-ohio.com.
Dec 27, 2009 | Wurlitzer Jukebox 1015 One More Time...
Juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
May 09, 2009 | Audio Players & Recorders
Juke box will take coins but won't play record
WHAT IS THE POSITION OF THE GRIPPER ARM(CALLED GRIPPER ARM THAT GRABS RECORD?)
OVER THE TOP OF THE 50 RECORDS? NEAR THE TURN TABLE?
IS THE OPERATE SWITCH IN PLAY POSITION ? OFF POSITION ?
DOCTOR FIX.
Credit card subscription up. how do i put another credit card in to play xbox live again?
Go to MarketPlace, Add Microsoft Points and add new credit card right there; then you should be updated and can renew subscription with the new credit card information.
Jul 04, 2008 | Video Game Consoles & Games
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
