Question about Toshiba SD-2805 Multi-disc DVD Player
Disc Error Suddenly my DVD player will not play any movies. I get a message Disc Error. Is the machine broken? Thank you
SOURCE: Unknown disc error
In my dvdr630vr plays only audio cd`s. Same problem?
Posted on Feb 01, 2008
  • 86 Answers
SOURCE: dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Posted on Feb 12, 2008
  • 286 Answers
SOURCE: movie skips and freezes during play
This is a common problem on CD and DVD players.
Altini is correct to a point. You can try taking the top case off, removing the DVD drive and taking the top off of the drive. Then use a q-tip on the laser lense. I use a little squirt of windex on the q-tip. Gently clean the lense even if it doesn't look dirty. Make sure you very gently work the lense up and down through it's travel. This will make sure no dust or dirt is interfering with the lense focusing.
Reassemble and try your movies again. This is a 50 50 proposition. If you still have the same problem, the mechanism has likely gone bad. Time for a new DVD player.
Posted on Feb 14, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Player suddenly freezes
Try running a dvd cleaner through it first, before trying anything else (the type that looks like a DVD with a brush underneath).
The regular DVD might have been a fluke (scratches, rental?, burned dvd?)
Was there anything special about the new Blu-Ray Disc - what was the tile? On certain titles, you may need the firmware upgrade found at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300
Posted on Mar 07, 2008
SOURCE: Toshiba SD-3980
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
read that
Posted on Mar 23, 2008
Disc Error: My question is a result of a recent problem that I have been having with your product and recorded DVDs. On certain movies, I have been able to play them with absolutely no difficulty. However...
some older dvd players dont play dvdrs very well, but most wont play dvd in pal format only ntsc some movies are recorded in pal, you can change format if you are using nero on the last stage wher you click burn choose ntsc
Apr 13, 2010 | Emerson EWD2204 DVD Player/VCR
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Mine is Sony DVD player..I insert a disc and it says "CAN NOT PLAY THE DISC" and then the player shuts off. The other DVD works fine.
HI,
Check the manuel some DVD Players do not support DVD RW or -R +R formats.When Ifirst put my burned movie in I got the message that the player cant play that format Just ignore that and advance the Video to where the movie is starting then all my burned movies played fine. My Pioneer BD 51 FD does support DVD RW +R -R formats so be sure that you can play burned DVD RW +R -R on your Sony player. I was in Wal Mart the other day and they had some DVD players on sale but on the box it said that they do not play DVD RW +R or -R Burned DVD's so be careful if you do buy another one I went to best buy and found mine. Check first it will save a lot of hassle later. This software works great but it may not play in your DVD Sony Player there is a list here of compatible DVD Players
OR
your disc is scratched or a pirated one
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Sony Televison & Video
Disc error: Playback feature may not be available on this disc
Ok well I have a brand new disc from the store with Percy Jackson movie on it and it will not play. The disc plays in other players in the house and other discs play in the player just not this one.
Aug 18, 2009 | Philips Magnavox DVD/VCR Dual Player
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Disc error "playback feature may not be available on this disc"
Hello arnita2211,
This error message is due to an improper format, that your dvd player can't handle. To correct this you need to use a program such as nero and in nero is a program called nero vision, that will recode the movie file into a dvd playable format.
You can download a trial of nero here
http://www.nero.com/enu/downloads-nero9-trial.php
You will have to purchase a license when the trial ends. Sorry we cannot give you a serial key for this as it is Illegal.
Thank you for trying Fixya!
Apr 08, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Mar 18, 2009 | GPX D1816 DVD Player
-bad disc reports
The problem with using rental discs is that they are dirty. Buy a dvd player cleaning disc and follow the instructions. These discs help to realign the laser. If this does not help try cleaning the disc with a disc cleaner. Also depending on how new the dvd is there have been a lot of discs manufactured outside of the US that have been bad. It may not be your machine but the discs. I personally went through 6 of the same movie before i gave up and rented something else that worked perfectly fine. Hope this helps you watch.
Sep 11, 2008 | Televison & Video
Portable dvd
err disc, what does it mean? My player suddenly displayed this error message, how do i solve it?
Aug 18, 2007 | NextBase SDV-17 Portable DVD Player
Toshiba SD-2805 Multi-disc DVD Player Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
