Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Both tem are showing zero F, how do I check to konw that ref and freezer part is working?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Use a thermometer and compare to units guage.
Posted on Oct 11, 2010
Sub-zero model 590 - replace dual water valve and now ice maker overflows with water
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 20, 2011 | Sub-Zero 632 / S
I vacuum the unit condenser about two weeks ago. Last night I noticed there is a constant humming noise and the freezer will not reach its preset temperature of zero degrees, ranging from 14 degrees to 8...
The cold control is the knob in the ref that turns it on and off and has numbers on it.
The cold control probably the culprit
If this doesn't work Do this
be defective and not shutting off. If your temp is warm proceed with the following.
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 13, 2011 | Sub-Zero 611 / O Bottom Freezer...
Sub zero 680 ice maker not working
NOTE: This
Leo Ponder
imufo2
Aug 05, 2011 | Sub-Zero 690 Side by Side Refrigerator
Service light is on, ref wont cool
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
Check cold control (thats where you turn it colder)
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Sub-Zero 650 / O Bottom Freezer...
Freezer not working but refridgerator section ok. this is a sub zero unit
It is a defrost problem since the ice that freezes on the freezer coils
 Its best handled by a Technician butyou could possibly do it by taking your model number to the nearest appliance parts store  and asking for the parts.  They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref  The parts store will have info  Also check evaporator fan in freezer If this was helpful please rate me
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net"
Sep 05, 2010 | Sub-Zero Bottom Freezer Refrigerator
The drip panel of my ref, 690/s is overflowing and dripping constanly. the water does not get evaporated. can you show me how to fix it?.
Check the door seal around the freezer... it is letting in moisture which defrosts and then ends up in the pan...
heatman101
Aug 27, 2010 | Sub-Zero 690 Side by Side Refrigerator
Our Whirlpool Gold GB22DK model is not working...the freezer works fine, but the refrigerator is warm and not working. What part would I need?
check the thermostat is working by turning the tem down it should drop the tem if its dont change the thermostat
Aug 22, 2010 | Whirlpool Refrigerators
Drain tube apparently doesn't allow condesate in ref to drain out
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 freezer (bottom) too cold. Tried to
probably bad control board. check this. push the on/of key. the whole ref and freezer nedd to stop. if you hear the compressor in the upper part of the unit or the fan. your contol board need replace.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
My freezer is beeping.
this beeping could be the high tem warning beeper,,,check the tem of the freezer if its not -18 or so turn up the thermostst to get it colder, if it still wont stop beeping the thermostat is fualty
Nov 19, 2009 | Amana Refrigerators
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
42 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
