THE LOCK LIGHT IS ON ALWAYS.WILL THIS STOP MY REMOTE FROM WORKING
  • rebs96 Oct 11, 2010
    THIS PROBLEM IS ON MY LEGEND LHD2 SET TOP BOX
My Mazda 6 remote control will not reset . Everything works with the key (windows and doors). The remote has new batteries . A Mazda technisian has looked at the car,but is baffeled as to why the remo
Well I assume you disconnected the battery to the car when repairing the switch..which is electronic. Mazda systems have to be reprogrammed after power interruptions or the whole system goes crazy. There is a weird sequence of ignition turns and door closures that is required in the program sequence. You will have to try to look it up or have a dealership give or do the sequence for you.
Feb 12, 2015 | Mazda Cars & Trucks
My interior lights stopped working, my radio won't come on, and my locks stopped working when the car is off I have to lock them manually. Also when I'm driving at night my brake and battery lights bl
Assuming you have checked all fuses, the next step would be to locate central grounding points (there may be several) and remove and clean battery terminals and the remote ends of the cables at their attachment points.Locating some of these may be easier with a manual covering the electrical system of the car:
Sebring manual
When removing battery cables, always start with the negative cable first and reattaching it last.
Dec 08, 2011 | 2001 Chrysler Sebring
I have a philips remote control and I need the code to control a pioneer DVD player
Though all remotes are differnet just try this it can be kind of standard. But not all remotes are always compatible
1. On the remote control, press DVD once and Turn DVD player off
2. Press and hold SET until the red light blinks twice, then release SET.
3. Aim the remote control at the TV and press SCAN. The red light will blink twice.
4. Continue aiming the remote control and click on and off at the DVD Player (which may take up to 5 minutes) until it turns off. Immediately press any key except VOL-, SCAN, or SET. If SCAN is pressed again after any key stops Auto Scan, the remote will continue Auto Scan of the next ID from where it stopped. If you have passed by the code that turns off the TV, press VOL- one or more times until the TV turns on again.
5. To lock in the code and exit Auto Scan, press and release SET the red light will blink twice.
1. Or if you have a code. Press Set
2. Wait for blinks
3. Put in code.
4. Test it and if it works click set if not try next one.
Jul 17, 2011 | Philips Televison & Video
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
Hazard lights won't turn off. Disconnected battery now hazards won't stop.
I see this is an old question, but I'll answer it because I ran into it myself - after hooking the battery up again, hold down the lock button on your little lock/unlock remote. If that doesn't work, hold down the unlock button. I always forget and end up doing one and then the other. In any case, it resets and the hazards should stop flashing!
Dec 22, 2010 | 1997 Subaru Outback
Remote control has stopped working. Have tried changing the battery of the remote control but that did not work.
Does the red light on the remote light up when you push any of the button
if no, replace remote
if yes, then try repograming the remote to the car again.
-Have remotes' ready. if you have two then fob#1 and fob#2 (doesn't matter which one is #1 or #2)
-each step has to be done within 5 sec or it will not work, but don't do it super fast.
1.turn key just to the "on" position (not starting) and push "lock button " on fob#1 once and release
2.turn key off
3.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
4.turn key off
5.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 8)and push the "lock button" on fob#2 twice.
8.turn key off and remove key from ignition.
if you did it right, remotes' should work again.
good luck
Dec 17, 2010 | 2003 Honda Accord
2001 Santa Fe.Remote keyless stopped working.No lock, no unlock. Replaced transmitter battery, LEDs light up as usual. Manual key and manual lock/unlock switches work fine. Thanks in advance!!
some time the buttons on the remote get worn out and it will light up but it wont unlock or lock. you can just buy a new case and switch the piece inside. If you have another remote try to see if that one works if it does then the remote case is your problem
Feb 14, 2010 | Hyundai Motor 2003 Elantra
All of a sudden several electrical issues
CHECK ALL THE FUSES UNDER THE DASH AND UNDER THE HOOD OF THE CAR FOR THE DOOR LOCK ISSUE
THE BREAK LIGHT ALWAYS ON , THERE IS A SWITCH UNDER THE EMERGENCY BREAK HANDLE THAT SOUNDS LIKE IT JUST NEEDS ADJUSTING
Sep 16, 2009 | 2001 Honda Civic
RCA RCR 3273 universal remote
for codes:
http://www.rca.com/codefinder
Nov 27, 2007 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
