Question about Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
The display panel on the door is not working - Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Connections on the door may be loose.
Posted on Oct 11, 2010
  • anna Sep 20, 2013
    How do you check to see if the connections on the door are loose?
My interior lights above rear view lights come on when i stop or brake,then go off when i drive again
Hi ...
Friend tracked a similar problem to wiring within, in his case, the front passenger door. Bumps, temp fluxes, just about anything might randomly cause an intermittent short in the wiring that led to the door- open, plunger switch ... which, ideally, makes interior lights go on when doors open and off when doors are securely closed.
He took off the interior door panel (suspecting the most used driver & passenger doors as the problem's source) and traced the bundle of wires that eventually fed the door, plunger switch. Can't recall if something was loose or missing wire insulation that just needed electrical taping.
I remember thinking that the door panel removal, w/o breaking the panel "clips," to assure they're intact for panel RE-attachment, might be a trickier pain for mangy of us!
Have your flashlight, ultra thin screw drivers & needle nose pliers handy as most clips are plastic ... & unpredictably unforgiving! ;-)
They're vaguely like the butterfly/toggles used to anchor hooks, etc. on to drywall. Just a solid piece of (usually) plastic, so no spring/hinged part.
Imagine a capital "T" inside of & over a capital "V" ... the top of the "T" fits a slot in the door panel & the V part pushed through a corresponding hole in the metal comprising the car door.
Hope this fix applies to & works for your prob, too!
Cheers! ;-)
Jim in Pittsburgh
Jun 08, 2014 | 1997 Lincoln Continental
Control panel does not work
You will need to replace the display. Here is the part to order.The dispenser panel unsnaps from the door of the unit.
Nov 27, 2012 | GE Profile PFCS1NJWSS Stainless Steel...
Front load washer door will not lock
Hello Phyllis Emmett - Do you notice any error codes displayed on the control panel or lights blinking? If so and the panel displays "DR", the door may have a defective door lock switch. However, if panel displays "DDO" either the drawer is not closing, magnet may be missing or have a defective reed switch, which you will need to contact a professional to diagnose the unit.
Sep 24, 2012 | Frigidaire Affinity ATF7000E Front Load...
GE Profile refrigerator pss26sgrcss isn't dispensing water, and 2 days control panel isn't working either. Not running and not cold at all, what are possible problems and solutions?
check for power at the display if power is present then you need a new interface (display) if no power is there then you need a new mother board located on the back of the unit square panel..mother board part#- WR55X10942--interface (display)-part#WR55X10390
Mar 27, 2012 | Refrigerators
Display only works when it is flipped over
hi, if i understand wath you means that is the pallet
doors display switch /when you flip the panel display
theres a switch in the display doors thats makes the display turn upside down to viewed correctely
i get this problem with different cam i got to fix
that mean :repair is need ,
hope that will help
Mar 09, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
Control panel not working and no lights
Hi. you will need to replace this non functioning Control Panel asap and, test the light pressure switch for it's operational value. If the switch is OK, simply replace the bulbs.
May 24, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
The display panel want work.
LOOK MIN TH EBACK ON THE MAIN CONTROL BOARD AND THERES A FUSE THAT YOU MAY HAVE BLOWN
Mar 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
No display on LCD panel on my whirlpool microwave
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Feb 11, 2009 | Westinghouse Microwave Ovens
Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
526 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
