Question about Whirlpool SB160PEE Gas Single Oven
I press bake and start on my oven.And it doesn't do anything.I've tried everything else.This is my first time baking bread!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Select a temperature also , then it will
Posted on Oct 11, 2010
How do you stop the clock ticking?
You could turn off the oven at the isolator switch. Turn it on again when you need to use it.
The time really only needs to be accurate when you make use of features like a delayed start when baking bread, or to stop baking meringues and let them cool slowly in the oven.
Just be sure to check that the Auto/Manual switch is set to manual unless you're doing the above type of baking.
Feb 28, 2014 | Candy Ovens
GE Range JSP68 shuts off while preheating
I have an aging JSP68. First, take out the range control (held in by just a couple of screws, disect it, clean it the best you can, dry it. Be careful not to break it because there is no replacement. Pay special attention to the membrane buttons. They tend to stick. Realize the broiler element turns on sporadically to reach the set temp quickly, the bake element should be solid on. Check the "header" (the long double strip of pins) connecting the range control. I had to resolder mine. Another insult was that I baked a bread recipe that required you put water in the oven to generate steam. The steam made this oven literally go bonkers. The relays started to chatter and just a half minute of this will destroy them. Also when you press bake keep it pressed for a few seconds while adjusting the temp to 170 then release. If you don't hear the bake relay click on, try again. Another thing you could try is to press all of the buttons once, this should help to unstick them if any are stuck.
Aug 07, 2013 | GE Profile JTP18 Electric Single Oven
My oven is not baking properly. The tops of banana bread and cinnamon rolls are browned and bottoms still soggy.
It's possible the lower bake element is not working. If the oven takes a long time to come up to temperature, that's a good indication that a baking element (bottom, broil element is on top) is bad.
Apr 27, 2011 | Whirlpool GBS307PR Electric Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Aug 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
Delay or time bake
You can find the manual at www.managemyhome.com, and the instruction is on page 11.
You make sure the time is set correctly.
You press Bake, and set the temperature you want to bake.
You press Cook Time and enter the amount of time you want the oven to cook.
You press Delayed Start, and enter the clock time that you want the oven to start.
Jan 30, 2009 | Kenmore 47772/47774/47779 Electric Double...
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Whirlpool SB160PEE Gas Single Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
