Question about Philips Magnavox 51MP392H Rear Projection Television
Blank screen and chirping
The front LED comes on and mine beeps. I just fixed the convergence on mine and it was working fine. When I unplugged the eft board with the convergence IC's on it the bulbs came back on, but of coarse there was no picture. I took that board out and for some reason it was wet. I cleaned it with alcohol after changing the IC's and resistors. That was hours before I put the board back in though, and I made sure it was dry. Is this some sort of leakage from the IC's? What is this new problem all about?
    Problem Solver:
  • 17 Answers
HI,
I THINK ONE OR MORE TUBES ARE GONE.CHECK TUBES FOR CRACKES UNDER YOKE,THANKS.
Posted on Jun 04, 2008
No picture, only beeps..philips 37pfl
The chirp or beep is a indication of a short on a line with fairly high voltage, over in most cases 100 volts DC.
Time to decide if you want to fix it (I would not as boards are rather expensive for this brand) by having a shop look at it OR retire/recycle it---average life on these sets (any brand) is about 4 years.
Dec 14, 2012 | Philips Televison & Video
Screen is scrambled. Working fine until I unpluged the TV one day. Is it a fuse?
If it looks 3d or warped its a convergence problem
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself
Apr 22, 2011 | Hitachi 51F500 51" Rear Projection...
I have the Hitachi 53FDX20B Manufactured in October 2002. It had the convergence problem where the upper left corner was a mixed up coloring and kind of a wavy line that didnt move. Color correction...
You need to replace both of your convergence ICs STK392-110s
use 120s Mats has them 1-800-628-1118 Check Low ohm resistors near ICs 1.8ohms 3.9ohms 2.7ohms etc... RK48 RK50 RK54 RK58 RK60.
On front of convergence board is a blue contact switch this is how you enter convergence pattern R/G/B to adjust convergence,
you can remove Front bottom panel and see the contact switch from front of TV With TV on Press and release then Pattern should come up. When you call Mats ask if they have Convergence Kit that has ICs and resistors in it!
Sep 26, 2010 | Hitachi 53FDX20B 53" Rear Projection...
I unplugged my ps3 to put it into a different room and it worked fine, then i put it back in my room and now it comes up with a blank screen?
Connect your controller into the USB port and press the `P` button.
If still no joy, then hold the power button down at the front of the console until your hear one beep then eventually another. When the PS3 shuts down, let go of the button.
Then press and hold it again until you hear the first beep, 2nd beep then a double-beep.
This will bring up a 6 option menu, select `Restart System`.
This should sort the problem!
Good Luck!
Jul 04, 2010 | Sony Playstation 3 (PS3) Console
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
Looking for manual for acer aspire m1201. its on complete lock up powers up and thats it
Please go thru this link to find the manual.
http://support.acer.com/us/en/acerpanam/desktop/0000/Acer/AspireM1200/AspireM1200nv.shtml?Team=%2Fus%2Fen%2Facerpanam%2Fdesktop%2F0000%2FAcer%2FAspireM1200%2FAspireM1200nv.shtml
Feb 07, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
48 jvc
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2009 | JVC AV-48WP30 48" Rear Projection...
Phillips chirping
two STK392-120 convergence modules that usually cause the beeping. So I changed them both again, but I also found two open 7.5 ohm resistors are in the general area of the convergence modules, and I replaced them as well. I also replace 1 swollen capacitor that was probably going to blow in the future but not really a problem yet.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Philips 43PP9202 43" Rear Projection...
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
