Question about Refrigerators
The water from the Kenmore freezer comes out clean, but when ice is added, there is visible white, pulp-like specs floating in the water.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Replace your filter.
Posted on Oct 11, 2010
Countertop Icemaker is only making a few thin cubes every hour , maybe buildup from bad water ! What can i pour in it to clean ?
I would switch off the power, disconnect water and keep it so for a few hours. While power off, clean whatever visible build up you find. And make sure you shut the water valve before disconnecting unless you want another project! After a few hours connect water and power and wait until ice made. Goodluck.
Apr 05, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Not making ice
check for a stuck float switch. located near the water pump. Usually white plastic with a tube on top and a black boot at the bottom. Tap on it lightly while unit is filling with water. If that works, you need to disasseble and clean.
Sep 30, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have a Hoshizaki KM900MRH ice maker. It will run fine for a couple days then shut off and beep 3 times within 3 seconds. I am told by tech support that it could be a float switch. Where is the float...
float switch is usually a white plastic unit with a black rubber boot on the bottom. you need to drain the water out of the sump before doing anything with the float.
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice with white flakes from refrigerator ice maker
Try setting the freeze temperature down to the initial setting selection. Your freezer is getting to cold. Hope this helps.
JimmyC
Sep 28, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Takes too long to drop ice
Unit is functioning on the back up freeze timer.
Cause:
Float Switch stuck in the up position.=Empty sump, remove float switch (Carefully and watch the small pin that keeps the float inside). Clean and reassemble.
Water Valve leaking by:=Only fix is to replace. Turn unit off. If water continues to run in and overflows the sump, it's leaking.
The other things that can cause this requires a qualified tech as it is a refrigeration problem.
Hope this gets it for you.
Jul 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Floating bits in Whirlpool fridge-freezer crushed ice water
Ice cubes freeze from the outside, so the center of the cube is the last to freeze. Ice is pure water, only H 2 O, so as the ice cube freezes, all of the dissolved minerals are pushed to the center. Near the end of the freezing, there isn't much water left in the center of the cube, so these minerals become very concentrated, and they form the "white stuff" – the technical name is precipitate. The hardness minerals that cause the "white stuff" are not toxic.
Mar 20, 2009 | Freezers
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
