Question about Ovens
When using the oven I get an error message of F3E2. I was told to turn the power off at the breaker box by a Wirlpool associate and that should fix the problem, which it did but now its not heating to the correct temp.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
A reset switch is what he is talking about. Turn power off at breaker for one minute if this does not rectify problem have a service tech come out. A local appliance guy is usually the cheapest and best route to take as the brand name guys are usually few and far between.
Posted on Oct 11, 2010
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
F3e2 error
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
We set our wall oven for self-clean and received an error message after about 4 hours that told us to turn off the circuit breaker. We are unable to turn the circuit breaker back on again.
If you cannot turn the breaker back on then it is no good...some breakers do take some very firm effort to get them to come on...but the oven may have ruined the circuit breaker...
Circuit Breaker Keeps Tripping
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Thermador SC302T Electric Double Oven
My top oven is displaying some kind of error message. First it was F3, now it is F2. a loud ding noise comes with it. Help!!!
I get this, and F7 sometimes, especially after self-cleaning. Was told by a repairman to turn off the power, the breaker in electrical box and leave off. I usually leave off for anywhere from 5 hours to the next morning and then flip the breaker back on. Then it is fine. Happened to me 4 days before Thanksgiving too!
Nov 23, 2010 | DCS (WOTD-227) Double Oven
Error message f23
it is a mis-communication between the panel and the timer. You have to turn off the power (throw the breaker) to the oven and leave it off for one minute. When you turn the power back on the oven should reset itself. If you can't turn the oven on then a service call is needed. My oven came on and I was able to use it after that.
Jun 13, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Kenmore Gas oven is giving F8 error code
Unfortunately the F8 usually means an EEPROM data shift error. Try turning the power on and off several times. If error continues, you have no choice but to replace the ERC. Check on line for the best price. There is a group in the Chicago area that repairs ERCs. Check them out at www.cgiltd.com The failure of the your power system may have been associated with a surge either as the power went off or when it came back on. It may have been the surge that did the damage.
May 19, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
138 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
