Question about Logitech X-240 Computer Speakers
Only getting sound from the sub...any idea where I went wrong?
I just got my system today. All the speakers are working, except the sub-woofer. Any ideas what could be wrong (if not DoA)?
Did you connect power to the sub-woofer? Most subs have their own amplifier. Just check if there is also an on / off switch on the sub.
Apr 18, 2015 | Frisby 5.1 Surround Sound Home Theater...
Sub not working
there might be transistors that went bad
May 01, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
I have a yamaha htr-5240 receiver. Also have a 6 speaker polk-audio surround set.Center,2 rear,2 front,& the subwoofer. The sub is a psw-250 with no sub out or LFE.I can't figure out what i've done...
First, look at the sub, their should be a switch for "auto" "off" "on" switch it to "on" Then use the Left input on the sub not the right. Left is for mono. Now, if you still dont have any sub, disconnect the RCA at the receiver and touch the end of the RCA, if the sub is on, you will hear a loud humm. Now, go back into the receivers Menu and go into manual setup, find "Audio" and select "Auto". That should do it. If not, put the receiver on "Tuner" and set the sound to 7 channel stereo (I'm not sure if the HTR series has this) or "Adventure" I'm a Yamaha RXV series Dealer so the names may differ. (check in manual for audio surround settings) Anyway, this should let you know if you've got all your spkrs working. Then make sure your TV's external audio is set to "Fixed" (it may be called audio out) depends on TV type. Scroll thru TV's audio menu. If you still have problems post a comment and I will help some more. Hope this helps
Jun 21, 2009 | Audio Players & Recorders
No sound in sound bar and subwoofer
It could be that the unit is bad, it could also be that the device providing the input is bad. I doubt the cables are bad, but that could be also. Could it be possible that your television has a menu setting that turns the outputs off and on?
Even without the sub, you still get sound through the Bar.
Only way to test it is, different cables, alternate device to provide input for sound.
Dec 14, 2008 | Boston Acoustics TVee Model Two TV...
Blown solobaric?
how did he messed up? anyways, if u push the cone of the sub down and u hear a sound like "TUN!" its most likely ur sub is irremediably damaged. The cone needs to come up perfectly as a good sub would do. I need to know exactly what ur friend did b.c it is quite weird to mess a good sub by slightly switching cables
May 24, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
ZX1500.1 Major Problem
If the subs are pushed to their limits straight out and remain there as long as the amp is on, the amplifier probably has shorted output transistors. If the speakers are moving in and out like they would be on a bass note, there may be something wrong with the shield ground of the head unit.
Dec 13, 2007 | Kicker ZX1500.1 Car Audio Amplifier
Subwoofer Wont Work
If the connections are correct...?
then it doesn't sound like theres a problem with the amp.
make sure the amp is not to powerful for the sub?
eg: 1000w amp, 500w sub.
Sounds stupid but it happens.
make sure the gain / volume is not too high!
if your BMW has a totally sealed, metal boot area this doesn't help.
Dec 11, 2007 | Sony XM-2150GSX Car Audio Amplifier
Logitech X-240 Computer Speakers Logo
16 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
