MY mouse has a red light that continously flashes. I charge it at night and all day the red lit flashes. Time for a new mouse or what?????
    Problem Solver:
  • 13 Answers
You need to tell us more then "MY mouse"... but I'll try to help.
First: there must be button to power off/on your mouse, switch to off and then on. If red light continues to flash clean connections on mouse and on dock (where you charge mouse), try to charge it, if red light continues to flash check if you can replace battery if not it's time for new mouse.
Posted on May 31, 2008
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
Two red flashing led lights flashing. Constantly get the same problem fix and am tired of this problem had 4 controlers replaceded and several other things done almost $10,000 dollars done last year alone...
The 2 flashing red lights indicate a low battery. Did you have the batteries replaced? and did you have the charger checked? The charger could not be giving you a full charge or you didn't charge the batteries correctly. It takes about 9-10 charges to bring the batteries to 100% operating capacity. Always charge the batteries before using after installing new ones and then charge nightly when you sleep. When you get up in the morning the batteries should be fully charged and last all day. Never charge more than 12 hours and always store or put up fully charged Hope this helps and sorry that no one can seem to help you except spend your money needlessly
May 25, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
How do i charge it?
You do have re-chargeable batteries in it? You could try a new set of batteries and there's usually a "Connect button you can press to reconnect it after installing new batteries.
Jan 02, 2010 | Dynex Wireless Optical Mouse
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Flashing red light
Most wireless mice will hibernate after a short period of inactivity. If something bumps the desk or moves the mouse it will start scanning again. If you don't like the light, you could try a laser mouse (no red LED flashing).
Feb 08, 2009 | HP Wireless Optical Mouse
My camcorder-camera doesn't charge....
Ihave a canon zr 40 mini digital vidio camera it want take charge the battery is new.Does it have to be off to charge it? IT is suppose to flash when charging and it want can you helpme with this problem?
Dec 09, 2008 | Video Cameras
RECORDING A VIDEO AT NIGHT
The flash unit is for still photos only. By design it can not be used when shooting video, because it can not stay lit (the flash fires from a stored electrical charge, and needs time to build up another charge).
May 02, 2008 | Canon IXUS 960 IS Digital Camera
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Message Light flashing continously
Resetting the New Message LED
If the LED remains on after you’ve retrieved your messages, you may need to reset
the indicators. With the phone is in standby mode, press and hold find handset on
the base until the paging sound stops (about 5 seconds).
Dec 12, 2006 | Uniden TRU8865-2 Expandable System...
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
