Question about Eureka 2961AVZ Bagless Upright Vacuum
Looking for the roller part number for Eureka 2961AVZ. The ball bearing on one of the side broke on the existing roller.
  • 377 Answers
You should be able to find the roller you are looking for at this URL:
http://www.vacuums24x7.com/eualseup29se.html
Paul
Posted on Oct 11, 2010
  • pwillitz Oct 11, 2010
    I am sorry my solution was of no help to you.
    Paul
Eureka TRUE HEPA Whirlwind Bagless same problem seems...roller just stopped...took everything apart and turned it on just in time to see belt melt...I was able to get the end caps off both sides at first...
If you are able to remove one end cap, the brush roller shaft can be removed and the other bearing is exposed for examination and removal of the hair that probably is clogging it. After cleaning and reassembly the brush roller should rotate freely. Clean any burned belt residue from the motor shaft and install a new Eureka belt.
Aug 02, 2013 | Eureka 2961AVZ Bagless Upright Vacuum
Brushes do not spin when it is on low carpet you have to have the knob on high carpet for it to work.
That means that the belt is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet. The lower the setting the more resistance. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Nov 19, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
This the 2nd roller i put on here and it keeps
Keep the brush free of hair and thread, check your housing for excess wear and only use a genuine belt. As these uprights have gotten cheaper the reliability and durability has gone out the window. If within warranty consult a warranty center.
Sorry to say most bagless uprights are becoming disposable ,not highly serviceable....Retailers make huge money on expensive filters and in 3-5 years the vacs are in the landfill with unused filters still in your closet
Oct 11, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Belts breaking frequently
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Feb 28, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka 2961AVZ Bagless Upright Vacuum Logo
61 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
