Question about Frigidaire ATF6000ES Front Load Washer
E20 error is showing and the water is not draining out.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Pump is clogged or broken. Check your drain hose and also the filter to see if this could be the problem.
Posted on Oct 11, 2010
Cycle stops and shows error E20. Cylinder hold water and does not drain or complete cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
If still the problem persists then the problem is with the draining pump.The pump is not pumping out the water.Check the pump impeller it may got stuck due to some obstacles.Replace it and this wont come again.
Sep 16, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
My zanussi FJS1025W washing machine is showing the error code E20 and it wont let me spin or drain the water away. I have cleaned all the filter but still it wont do anything other than take in the water...
Thank You
Sep 09, 2010 | Washing Machines
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
My kenmore he washer will not drain all the water also have code E20 flashing
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
MY WASHING MACHINE HAS STOPPED 28 MINUTES THROUGH THE WASH CYCLE. ITS SHOWING UP E20 ERROR. ITS FULL OF WASHING AT THE MOMENT
Hi!
Error E20 means there is a problem with water draining. Please check the drain hose which may be kinked or squashed or the drain pump may be blocked. Another possible cause is totally blocked filter which is required to be cleaned to resolve the issue.
Thanks for using FixYa and revert for further assistance.
Thanks
Rylee
Jul 18, 2009 | Zanussi ZWF1430W Front Load Washer
Error code E20
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Jun 06, 2009 | Washing Machines
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
