Question about Ovens
Where is the fuse located - Ovens
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Usually behind panel in the top or the back depending if it is free standing (top back panel) unit or installed.(behind the control panel). Did you check your breaker box to see if it tripped a breaker ?
Also what brand and model is this oven ?
Posted on Oct 11, 2010
Why does the oven time flash but the oven won't turn on?
power to the unit by removing one or more fuses or tripping one or more breakers at the main entrance panel or at a separate panel. If the range is fused at a separate panel, this panel may be located adjacent to the main panel or in a basement, crawl space, or other location. If there is a grounding wire to the range, disconnect it. Make sure the power to the unit is off.
Servicing FusesIf the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.
If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
May 09, 2015 | Ovens
Fuse location on ge stove
If there is a fuse it should be located on the back of the unit behind a cover plate.Make sure to unplug stove before working on it.Hope this helps.
Dec 30, 2013 | Ovens
Oven not coming on
Do you have a flame sensor located next to pilot lite if so remove and replace at your local ace hardware store remember to turn of gas and electric is repaire are attempted. Next if no flame sensor your termostate sensor located in oven is the problem and must be replaced there is not test for that one just remember that connections are located on the top section of stove and always check fuses if equipt.
Mar 11, 2012 | Maytag Ovens
Where is the thermal fuse located and how do I replace it on Whirlpool double oven GBD307PRS03? Thanks
The thermal fuse is located on the back of the upper oven to get to it to replace it the oven would need to be removed from the cabinet and the back panel removed ( not fun but what must be done) here is a image of what the thermal fuse looks like.
GENE
Oct 15, 2011 | Whirlpool GBD307PDS Electric Double Oven
Where is the thermal fuse located on an electric whirlpool in cabinet oven?
hello,
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks,
    Oct 09, 2010 | Whirlpool RBS305PD Electric Single Oven
    Oven stopped working during baking process, switches shows no power coming through (don't light up) If a fuse is blown, where are they located?
    First check that the oven plug is not loose. If not that, you might have a tripped circuit breaker or blown fuse which are usuall located in your fuse or breaker box in the basement. Have someone with knowledge of fuses or breakers check it out. Keep in mind that you are working with 220 ac volts!
    Jul 30, 2009 | Ovens
    Where are my fuses located?
    From http://home.howstuffworks.com/how-to-repair-an-oven3.htm Servicing Fuses If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly. Electric Oven Troubleshooting Guide There are a myriad of problems that can cause your electric range or oven to malfunction. Click here for instructions on how to deal with specific issues. If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused. If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
    Jun 10, 2009 | Ovens
    How do I get into the fuse to change it on my whirlpool GBD307 PDQ7 oven? Where is it located?
    There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
    Enter here to find assembly diagrams and parts for your model.
    Contact the seller by phone if part is not listed on the website.
    Jan 02, 2009 | Whirlpool GBD307PDS Electric Double Oven
    Fuse location
    are you talking about the breakers that are outside or in the garage? Look where the main power goes into the building and there is where the breaker for the oven should be.
    Dec 24, 2008 | GE Profile JT952 Electric Double Oven
    SINGLE OVEN MODEL # RBS305PDQ16
    Probably refering to a thermal fuse. This fuse opens when heat is too high. Some of these ovens had a kit where you replaced the cooling fan, fuse and shimmed hinges to correct problem. You can access fuse by removing oven from wall. It will be located on back of unit. You can try replacing just fuse. It will probably be ok for bake and broil. It may happen again during clean.
    Oct 23, 2007 | Whirlpool RBS305PD Electric Single Oven
    Ovens Logo
    69 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
