Installation details about xerox phaser
Dear sir,
I want to know the details about the installation procedure of xerox phaser toner in that printer.,
    Guru:
  • 1,342 Answers
What model do you have?
Click HERE to go to the Xerox support site where you can get user manuals and drivers for your printer.
Posted on May 31, 2008
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
How do you reset toner counter on phaser 7750? Thanks
On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
Apr 01, 2011 | Xerox Phaser 7750DN Laser Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
How to refill xerox phaser 6125?
Just found a supplier for toner and reset chips for my new 6125. Don't know where you're based but in the UK you can use the following link:-
http://www.zinetic.co.uk/Xerox_Phaser_6125_Toner_Refill_Rainbow_Pack-details.aspx
In the US, a possible source from EBAY is:-
http://cgi.ebay.co.uk/4-Xerox-Phaser-6125-6125N-6130-6130N-Toner-Refill-HY_W0QQitemZ380126889100QQcmdZViewItemQQptZBI_Toner?hash=item588154048c&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Good luck.
MJN
Apr 07, 2009 | Xerox Phaser 6125 Laser Printer
Refilling toner catrige of xerox phaser3117 laser printer
Here is the solution you are looking for
http://www.tonertopup.co.uk/case_studies.asp
Aug 22, 2008 | Xerox Phaser 8400 Laser Printer
54 people viewed this question
jasbo
jasbo
