Question about Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
We are trying to find a re build kit to rebuild the faucet and switch the cartridge to have hot and cold on the proper side. Also how to rebuild the faucet when its fixed
  • 4,340 Answers
You get the rebuild kit FREE from Moen, they will ship it to your door.
The hot and cold is a hook up issue and not resolved in the cartridge. Just switch the input hoses. Sometimes the faucet is actually installed 180 degrees out and causes the same condition. I presume that it worked okay, except the reversal of the water... so switch the hoses.
Posted on Oct 11, 2010
Barclay 4073-PL Diverter Bathcock Tub: Thoughts on why the water pressure is low on the hot spigot but not on the cold, and not on any other faucet in the house?
Debris can get into the shower body/cartridge. Pull out the cartridge and flush the shower body and clean out the cartridge. Sometimes you need to replace the cartridge.
Nov 07, 2014 | Plumbing
Water barely comes out hot or cold
Make sure the filter screen that is screwed to the spout is clean and in properly. If so there may be debris in the ball control valve. If the faucet has some age on it, I suggest going to Home Depot and getting a rebuild kit. The kit contains disassembly instructions and all new valve parts. Easy fix and HD is a Price dealer. Thanks
Jan 08, 2011 | Price Pfister Single Lever Handle Faucet...
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
My kitchen sink will not let me turn the hot water off, it just keeps running. The cold water shuts off fine just not the hot side.. I turned the knob under the sink and the hot water turned off but now i...
Hi hi--
You'll need to rebuild or replace your hot water control stop--that's the valve on the faucet body. If it's a single handle control, you'll need to replace the control cartridge. If the faucet has two knobs, you'll need to locate whatever stem pieces are needed within the hot valve. Sometimes, on two knob faucets, you can get away with simply replacing the rubber pieces inside the control stem. If that is the case, your local hardware store should have manufacturer-specific rebuilding kits available. Be sure to locate the faucet's model name first! That should be written somewhere on the above-sink portion of the faucet body itself, and you should be able to see it without taking anything apart.
--Hope this helps.
Sep 27, 2010 | Plumbing
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
I have a Mico 7777 Kitchen faucet that was purchased in 2001.It has become difficult to move from side to side. Do we need to replace the cartridge in the faucet and if so how much does it cost and how...
it may not be nesesary to replase the cartridge you could just have some lime or sediment build up in the faucet a bad cartridge would effect your handle not your spout turn the hot and cold water off under the sink,pull the bonnet or cap off and the spout should just lift up take care not to damage o-rings pulling and reinstalling spout check for debris clean and replace spout to insure not damaging o-ring try putting a little vaseline on them 1.it will help go on easier 2.it will help to lubricate the swivel of the spout replace the cap turn your water back on. if your cartridge is bad your faucet will drip or constantly run
Apr 07, 2009 | Plumbing
Lavortory one handle faucet will not move to hot side
go to a plumbing supply store and obtain an american standard kit to rebuild the faucet. good luck
Jan 18, 2009 | Plumbing
Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
151 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
