Question about Epson Stylus CX6400 All-In-One InkJet Printer
Ink Cartridge The cyan ink wont print, it is half full and I have cleaned the heads about six times bit still no cyan ink prints, every other colour is fine. How do i take out the cartridge o clean the head, I normally follow the instruction to change an empt cartridge but I do not know how to take out a half full cartridge.
  • 1 more comment
  • Anonymous Sep 27, 2008
    You can't get to the cartridge unless it is empty. How can you make it move to the change cartridge position?
  • duramater Dec 08, 2008
    My printer has been working great for several years and many, many ink cartridge changes. Then just a few weeks ago I changed the black cartridge and now it won't print black. I've changed the cartridge 3 times and still no go. I've tried cleaning, aligning, turning the computer and printer off/on -- to no avail. Looks like a growing problem with these printers. In the meantime, I have no printer. Any other suggestions?
  • rendog50 Jan 10, 2009
    magenta wont print, everything is ok, Just wont give the magenta color
Put new black ink cartridge in and it reads full. Cleaned heads and nozz check. All colors working except black? Now the blue cartridge is reading empty and I cant print with new black cartridge. FYI I put two brand new Epson black ink cartridges in and chcked with Epson to make sure rite.
Posted on Nov 26, 2008
    Problem Solver:
  • 14 Answers
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
Posted on Sep 08, 2008
I used machine's ink jet cleaning program, without luck. Cyan and Yellow still don't print. What next?
My HP printer has a cleaning programme and a cartridge priming programme. I had trouble with my colour cartridge, in particular the cyan. The cleaning cycle never worked but the priming programme worked a couple of times but whenever the printer was left idle for a while the colour would not print.
I took the cartridge to a refill shop and the guy emptied the ink and steamed out the cartridge and print head and refilled it and then it did work for a time.
A new cartridge is expensive and so these days I just use it for printing black...
I think there must be something strange or different about the cyan ink. Sometime in the future I am going to try steaming again only this time with a deal more pressure than the guy at the refill shop used.
I am sure it will be kill or cure...
Deleting the printer and reinstalling it should be the next step to try. Sometimes my printer goes a bit eccentric or gets in a bad mood if I try and pause or cancel printing from the printer menu. I have learned not to do that with any HP printer. Once it gets in a bad mood the only cure is to disconnect it from the mains and leave it for half an hour before plugging in again.
My printer, incidentally, is a Deskjet 96 Cxi professional machine. I like it because it prints both sides of the paper and it cost me nothing.
Mar 06, 2016 | HP Officejet Pro L7580 All-In-One InkJet...
Printer wont print the color brown
Try cleaning nozzle with dry paper towel, cartridge should leave 3 streaks: Yellow, Cyan, Magenta.
If colours on paper seams to be tinted or mixed the cartridge needs to be reclamated, there is no other solution.
If there is an lack of one or more colours try to wipe nozzle with wetted paper towel in window cleaner. After few wipes, 3 colours sholud apper
Oct 21, 2012 | HP 60 Tri-Color Ink Cartridge
Magenta ink won't print though cyan and yellow print okay after refilling for the first time. Also, everytime I remove cartridge (color) the print head is full of ink blot. (is this normal?) I have tried...
Sorry for the delay in my answer. No you do not need to remove the ink from the cartridge itself. Soak remove the cartridge and soak it as is. You will get a huge colour change in the water but it will not use any more than 0.1ml of ink
regards GM
Apr 21, 2011 | Canon PIXMA iP2200 InkJet Photo Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Printer is Brother MFC215C. Cyan colour not coming
  1. Press Ink or Ink Management key on the control panel of the machine.
  2. Press 1 to choose 1.CLEANING.
  3. Press the up or down navigation key to choose the Black, Color or All you want to clean, and then press Menu/Set or Set.
The machine will clean the print head automatically. When cleaning is finished, the machine will go back online automatically.
Note If you clean the print head at least five times and the print has not improved, please contact Brother Customer Service from "Contact Us".
Feb 15, 2010 | Brother Multi-Function Center® MFC-215C...
Won't Print Yellow Ink
your yellow colour is used mostly please refil your colour cartridge or change your colour cartridge.
Jul 30, 2009 | Epson Stylus C44UX InkJet Printer
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
469 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
