Question about Dell Pocket DJ MP3 Player
I found my dell pocket dj and went to find software to be able to use my computer with it. Also to use the usb to charge it from the computer. but the software i got from drivers and downloads from dell does not seem to be working. what should i do?
  • 10,421 Answers
Cannot install software
Go to dell.com and enter the DJ's service tag ID on the back of your player on the support section. It will give you a list of drivers and software that you will need for your DJ. If you are running Vista, download the XP drivers. They will work fine.
Jul 15, 2009 | Dell Pocket DJ MP3 Player
How to i install a dell pocket dj to a dell computer
You use the USB cable and the software provided with the player. If you do not have the software you can download it from dell.xxx
Jun 06, 2009 | Dell Pocket DJ MP3 Player
Dell Pocket DJ does not charge using USB Cord
If you find none of this has worked you need to try some other decvie in the same usb port. If it is plugged in and operates correctly, you have narrowed it down to the dj unit. Since the chord has tested good, we should go to the unit itself. Four tiny screws located on the outside of the case need to be removed in order to open it. Carefully remove the hard drive, then the battery.
Now with the cable hooked up to the usb port you will use a meter to check some voltages. Perhaps you have a friend who can help. The batteries should read 3.6 VDC. Measured like that its not a true indication of the state of the batteries, but tell us that the charging circuit is probably working okay.
Put it back together carefully, making sure every connection is properly seated and there is no damage. Try it again, making sure you hold down the button for 3-4 seconds. If you have done all of this, the problem is electronic and at a component level. Suggest you take it or send it to the repair shop dell has.
Ted
Jan 16, 2009 | Dell Pocket DJ MP3 Player
Dell dj 5 will not charge up at all!!!!!!!
if you have any (car or home) mini usb charger it will charge it for a few seconds but do this multiple times until if at least turns on then charge it from your computer
Sep 15, 2008 | Dell Pocket DJ MP3 Player
Dell Pocket DJ 5gb music problem
i need a drivers for my pocket dell dj 5GB model number HV03T
Aug 07, 2008 | Dell Pocket DJ MP3 Player
Dell pocket dj 5mb wont turn on
there is a pin hole to reset it.On the botom side beside the dell logo you will see it.Use a pin to reset.
Good Luck
Jul 07, 2008 | Dell Pocket DJ MP3 Player
Quick question re: Dell pocket DJ 5gb....
From what I have read, yes, it charges via USB.
May 19, 2008 | Dell Pocket DJ MP3 Player
Dell Dj 5 will not hold a charge
FYI, replacing the battery did not solve the problem of the battery refusing to charge. Instead, I've spent $30 at batteryship.com and since I've opened the battery I can't return it. There must be a software or hardware failure that's preventing the unit from charging the battery.
Mar 12, 2008 | Dell Pocket DJ MP3 Player
My Dell MP3 Player Won't Charge
I had the same problem for weeks. Very frustrating. Try the following as it brought my pocket dj back to life. I found that (while plugged into an AC adapter) by inserting a paper clip in the hole on the bottom (reset button) and holding it there for 5 secs it would power cycle the dj then the charging icon would appear in the top left corner, however it did go away after 5 icon flashes. I did this repeatedly. I noticed that every time I pwr cycled it , I got more icon flashes and it would charge for a bit longer. Finally it charged completely. Weird but this is what worked for my player.
Aug 24, 2007 | Dell Pocket DJ MP3 Player
Dell Pocket DJ MP3 Player Logo
95 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Jax Planet
Jax Planet
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
