Question about Olevia LT37HVS 37 in. LCD HDTV
Syntax Olevia LT37HVS picture/video setting problem. ( I went to Menu from Remote control, then Brightness option & when i enter for brightness adjustment in remote it says "Adjust Only In User Mode".It did not allow me to change brightness,constrast etc . If i try to do the same manually from panel, contrast ,brightness etc controls does not move & stays at 50/default setting and the picture is quite dark , Please let me know the fix of the problem.
  • 14 more comments
  • KINGSHUK PAUL Oct 11, 2010
    Right , If i use remote for increasing brightness / contrast , it says "Adjust Only In User Mode"
    Now when i leave remote control
    slider appears on screen
    when i try to increase with vol switch slider moves to 51
    on decreasing it goes to 49,but not beyond these ranges and cannot save those too.When i exit it does not save 49/51 ,
    it goes back to 50 as it was. I also tried to set default factory successfully , but nothing really happens
    Right, if I use remote for increasing brightness / contrast,
    it says "Adjust Only in User Mode" & it does not allow me to play
    with any control (brightness, contrast, hue, sharpness etc).
    Now when I leave remote control & try with the switches
    on the T.V Panel, the slider appears on screen & when I try to increase
    with vol switch it moves to 51 & on decreasing it goes to 49,
    but not beyond these ranges and cannot save those too. When I
    exit it does not save 49/51, it goes back to 50 as it was. I also tried to set
    default factory setting which sets it to 50. after that if I try to increase
    those controls it behaves in similar fashion.
    Only picture / video setting works in the same menu is the advanced
    picture option where u don't have contrast / brightness option.
    Is something locked in my system / any component gone wrong?
    How do I identify and get it fixed? please help.
    Right, if I use remote for increasing brightness / contrast, it says "Adjust Only in User Mode" & it does not allow me to play with any control (brightness, contrast, hue, sharpness etc).
    Now when I leave remote control & try with the switches on the T.V Panel, the slider appears on screen & when I try to increase with vol switch it moves to 51 & on decreasing it goes to 49,
    but not beyond these ranges and cannot save those too. When I exit it does not save 49/51, it goes back to 50 as it was. I also tried to set default factory setting which sets it to 50. after that if I try to increase those controls it behaves in similar fashion. Only picture / video setting works in the same menu is the advanced picture option where u don't have contrast / brightness option.
    Is something locked in my system / any component gone wrong? How do I identify and get it fixed? please help.
    Yes i line was missed , i was trying Menu,Brightness,slider --- > vol / -
    I used T.V Panel buttons all the time to get it set.
    2006-7 , not under warranty , Is it going to be costly / worth going to T.V shop
    yes 51 , lowest 49
    highest 51
    highest 51 & lowest 49 ,but it does not same those. Using factory default setting also does not help.
    Is it worth getting it checked / any clue what could be wrong with this T.V ? And will it be worth ?
    Sorry for the inconvenience , was using this portal for the first time , I am not a T.V person ,
    But Question for you is ... Is it going to be expensive or worth trying ? I guess main boards
    are expensive. Please suggest accordingly.
    Hi Tim,
    If i happen to get a working main board,can u pls send me step by step guide to replace it ?
    I guess there would be latches / bus cable which i can connect to it (like computer motherboard).
    If you can please send me the guide.
    Paul
  • KINGSHUK PAUL Oct 21, 2010
    Thanks a lot for helping me out.,
    I fixed myself for $50.00 replacing the
    main board with a working one.
    Thanks
    President:
  • 2,777 Answers
Strange, so nothing lets you adjust those settings? The sliders do not even move?! It should definitely be adjustable in just the way you are describing. I am researching this now, but please confirm, nothing moves on the sliders?!
Posted on Oct 11, 2010
  • 6 more comments
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    I didn't get your full comment, now when you leave your remote...? Have you tried adjusting it with the buttons on the actual TV?
    Tim
  • Tim Grayson
    The highest it will go is 51?!
    Strange, something may be going on with the main board of this TV...
    Tim
  • Tim Grayson
    Yikes, something strange is definitely going on here, it sounds like it may be an internal hardware problem if it will not even save those settings. The main board of the TV is not permitting you to adjust the settings, or save any slight changes. How old is this TV? Hopefully still under warranty :(
    Tim
  • Tim Grayson
    Please try to consolidate your comments... it is tough to stay on top of it when there is a new comment ever 30 seconds that was a continuation of your last sentence.
    Tim
  • Tim Grayson
    Sounds like the mainboard has failed for sure, I don't recommend you try to do the work yourself unless you are a tv repair person, it's very delicate work for sure.
    Tim
  • Tim Grayson
    I saw all your other comments, no need to reply to each individual one of mine here. Seriously I have like 14 emails from you here in less than 4 minutes.
    Tim
  • Tim Grayson
    Sorry about the delay, had to run somewhere for a while. It is going to be quite expensive, definitely not worth it. Since this is a 37 inch TV you can replace it for less than $400 if you look around online a bit. The repair will end up costing more than that :(
    Sorry about that
    Tim
  • Tim Grayson
    There is no real "guide" for it. The old board basically just unplugs from the inside of the TV chassis, you will be able to locate it once you have a new one, and can verify by making sure it is the same part number when you pull it it. From there you can just pop in the new one. It should just have a few push in connectors, no bus cables to my knowledge.
    Thanks
    Tim
Unable to change the aspect
Olevia sets tend to have a button on the remote to adjust this. try the zoom button as well. or in the picture settings in the menu
May 07, 2010 | Olevia LT37HVS 37 in. LCD HDTV
The tv is only showing the picture in a small box on the screen. The re.st of the tv is blue. How do I fix this?
you will have a button on your remote control that allows you to select what picture size you would like in your case it sounds like you have it set to 4:3 and it should be set to 16:4 if this fails check your menu options as one of your factory default settings may have been changed by mistake
Jan 31, 2010 | Olevia LT37HVS 37 in. LCD HDTV
What does the tv have to be set on to be able to use the dvd player?
You will need to go to the video source selection either on your remote (if available) or through the main menu. Our Olevia has source selection on the remote itself.
Dec 27, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 537H LCD - Set up options now disabled
No idea what happened but about an hour after posting this the TV started to function properly - now I can switch everything that was previously lokced up. So I'm all good - hopefully it doesn't do it again.
Nov 08, 2009 | Syntax Olevia 537H Television
I need to know how to reset the tv (olevia model #lt37hvs) the tv is unable to scan the d-tv channles because of it being locked
Go to menu -picture- mode- power up - put it on home setting than all controls should be unlocked I think ur in showroom setting 99% of people who reset there factory settings get this problem
Jul 08, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Unlock Olevia remote control
Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***
Nov 14, 2008 | Olevia LT42HVi 42 in. LCD Television
Can't remove blue PIP (?) section in lower RH corner
I have the Olevia TV with RC-LTU remote, To get rid of PIP just press the (VIEW) button twice.
Nov 13, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Picture too dark
Capacitors on the Ysus is bad. Buy a new Ysus board or change the 14 components on it from a repair kit
Feb 27, 2008 | Televison & Video
RCA REMOTE CONTROL CODE FOR OLEVIA/SYNTAX 237 HD TV
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
Satellite Box - 00392
Olevia TV - 11610
Enjoy!
Nick from Ft Myers
Feb 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia lt 30 hv
You both need to IMMEDIATELY download your warranty from the Olevia website. Read it completely. If you are still under warranty, then contact them IMMEDIATELY in writing pursuant to the warranty and demand that they fix the TV for free pursuant to the warranty. Do not accept "No" for an answer. Document every communication and contact you make, including date, time, who you spoke with (first and last name and/or employee number), and the content of the communication.
Do not delay on contacting them, because the warranty is controlled by the date you purchased the TV. If it passes, then you are totally screwed. Olevia will ignore you.
ALTERNATE SOLUTION:
Do not buy any Olevia or Syntax products in the future. Tell everyone you know to not buy their products either.
Dec 24, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
334 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
