Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge shuts off regularly on it's own - GE (PSS26MSRSS) Side by Side Refrigerator
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
A short circuit may be the cause of this, Is the fridge still under warranty ? Also check connector at top or bottom of door, it could be loose.
Posted on Oct 11, 2010
  • ozmets Aug 18, 2011
    i have the same problem with my ge refrigerator and it turns back on when i move it by shaking it. is there a simple solution? thanks
Why does unit run for 3 hours shuts off then 15 minutes later starts running again
Sounds normal. A fridge will cycle on and off regularly to maintain the temperature correctly. If it kept running non stop, it would turn the fridge into a freezer.
Sep 17, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have an AEG Santo 72348 ka fridge that is supposed to be self defrosting. Mine regularly freezes up inside. Any help ?
Usually this is a symptom of a faulty door seal or a very frequently opened fridge they extra moisture load from the environmental air.
Feb 18, 2013 | AEG Refrigerators
E442B Fridge is not cold & some ice build up in fridge. How do you remove the back of inside of freezer to check ice build up there?
don't mess about with it just remove items and get a new one sound like its leaked it's gas (BUT DON'T PANIC) its not harmful and its not going to blow up! you could call a engineer but a lot of the time your just as good putting that money towards a new one
your friendly domestic appliance engineer chris
Dec 05, 2011 | Refrigerators
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Ice maker hooked up for the first time doesn't work.
Hi, The storage is usually on the back fridge wall near bottom. Your answer indicates the demand solenoid is not operating. You will need to check wiring connection at the solenoid, and at the ice maker plug. Best of luck.
Apr 27, 2008 | Samsung RB215LASH
Ice Maker
  1. Water comes from water pipe, usually with a shut off valve (open??).
  2. Fridge has a small filter (for sand etc.) at inlet. (not clogged??)
  3. Water travels to solenoid valve, and waits for request. (do you hear it click when water requested??)
  4. Water usually goes to a fine filter..(these fail (plug) quite regularly).
  5. Water goes through storage in back of cool section (Inside fridge- is it full of water?).
  6. Water goes to ice maker on fill request.
  7. ?? Is the power switch "on" (to icemaker)??
  8. ?? Is the full / stop filling paddle/bar up?
  9. ...ask me more questions
Apr 21, 2008 | Whirlpool ED5FHEXMQ Side by Side...
No water for ice maker or at door
  6. Water goes to ice maker (door) on fill request.
  7. For Ice maker:
  8. ?? Is the power switch "on" (to icemaker)??
  9. ?? Is the full / stop filling paddle/bar up?
  10. ...ask me more questions
  11. In your case the solenoid valve or more commonly the filter need to be replaced
Apr 21, 2008 | Refrigerators
Ice maker not making ice whirlpool gold side by side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
47 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
