Question about Polaris 3900 Sport Pool Cleaner ()
My polaris 3900 moves across the pool with the front wheel of the bottom, the wheel on the 1 wheel side and the back wheel are on the bottom.
  • 640 Answers
Check your wheel RPM. If the pool cleaners RPM is over 32, reduce the water flow so that the cleaner makes proper contact with the pool's surface. Verify the back-up valve is cycling. Lift the valve out of
the water and watch the jet. It should come on and go off. You might also need to adjust your thrust jet if it is causing the cleaner to lean too far to one side.
Posted on Mar 17, 2011
Sport 3900 is doing wheelies will not stay level to clean
1. Check the wheel RPM. If not in the 30-36 RPM range, refer to the manual for adjusting the wheel RPM.
2. Adjust the thrust jet downward.
3. Verify the backup valve is cycling. Lift the valve out of the water and watch the jet. It should come on and go off.
4. Check for water inside the head float.
5. Empty the filter bag.
You can download the 3900 Manual from the Polaris site
http://www.polarispool.com/Pressure/Polaris-3900.aspx
It will show you how to check the wheel rpm and how to adjust the thrust jet and check and adjust the float.
Jul 06, 2014 | Polaris 3900 Sport Pool Cleaner ()
My polaris 3900 is not moving at all
if pressure is ok at wall check inside to see if hoses or belts or gears on wheels ok
May 26, 2012 | Polaris 3900 Sport Pool Cleaner ()
My Polaris 3900 Sport is on it's side. I turn it back up on all 3 wheels and it hits the side of the pool and goes back on it's side again...going in circles.
With these automatic pool cleaners, if they are not staying firmly on the bottom of the pool, it is most likely that there is air in the appliance casing.Try submerging your cleaner. Keep the cleaner vertical while you are putting it in slowly to let the air out. Ensure the unit sinks to the bottom of the pool.
May 20, 2011 | Polaris 3900 Sport Pool Cleaner ()
The wheels on my Polaris 3900 don't move. Plenty of water coming thru the thrust and the tail wags. When I move the wheels manually they all move together.
There are a couple things that you should check with these pool cleaners if the wheels are functioning properly. Check the filter screen in the in-line filter assembly and clean if necessary.Make sure that you do not have any debris or obstructions that could be halting wheel function. Even though you seem to have plenty of water, check the RPM and make sure they are between 28 and 32.
Jan 30, 2011 | Polaris 3900 Sport Pool Cleaner ()
My polaris is doing circles. it appears the single wheel doesnt move like it used to
i've just discovered i have this same issue with my polaris 3900. the machine is less than 3 months old. there is a small metal "gear" in the wheel hub just behind the blue "hub cap". a single screw holds it on the axle. it appears that the gear has worn the out around the hub causing it to slip and not be able to drive the wheel.. it appears that the solution would be to buy another wheel.
Dec 31, 2010 | Polaris 3900 Sport Pool Cleaner ()
Polaris 3900 is going in circles
If the cleaner is running in circles to the left the chain has come off the double side. To fix take bottom off and place chain where it is riding on the center sproket. To test turn one wheel and all wheels should turn. Also on the axel blocks the wheels are attached to can be adjusted to allow more tension on the chain.
Jul 31, 2010 | Polaris 3900 Sport Pool Cleaner ()
Polaris 3900 Sport Pool Cleaner () Logo
492 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
