Question about Mitsubishi WD-65735 Television
Replaced lamp wont come on ? - Mitsubishi WD-65735 Television
  • Mitsubishi Master
  • 5,138 Answers
You need to make sure all Fans are running and to Look on power supply board for Bad Capacitors,they will be vented,swollen or puffed up on Top .
Ballast Board is what powers Lamp on it could be Bad
Google to this website and type in your model#
Encompass Parts Distribution 1-800-638-3328
Posted on Oct 11, 2010
Bulb will not come on . I replaced with new one & still wont come on.
Sounds like the ballast is at issue, If you have the correct lamp for your ballast. Samsungs are very critical that the lamp be matched to the ballast, often replacement lamp dealers dont take that into consideration when substituting samsung lamp numbers. Was the lamp a samsung lamp or a generic replacement?
Jul 20, 2011 | Samsung Televison & Video
Can't reset lamp replacement message on a Sony KDS-50A2000. Any help is appreciated.
If lamp has been replaced then press Menu button on remote and select Settings then go to last option Lamp Replacement and follow instructions there.
TV wont show you lamp replacement message any more.
Aug 13, 2010 | Sony KDS-50A2000 50" HDTV
Tv wont turn on
It does sound like the lamp is your problem. You can remove it and inspect it visually for obvious signs of failure. Usually you will see that the arc tube, the glass tube down the center of the lamp, has shattered. Clean out the broken glass from the lamp compartment carefully before replacing the lamp.
Good luck.
Nov 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Lamp light is on. TV wont turn on?
Lamp light is On that means lamp is dead and requires replacement.
How old is this TV and did you replaced lap recently?
Lamp replacement procedure would be written in user manual.
Thanks.
Nov 26, 2009 | Samsung HLP6163W 61" Rear Projection...
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Replaced lamp on WD57731. green light turns on then a ornage light, under lamp blinks
Please put back lamp cover, the last plastic grille that were removed to replace lamp in TV.
TV sense that lamp cover is not either put back or not fixed properly so it wont turn On. Check lamp cover and problem will be solved.
Thanks.
Nov 14, 2009 | Mitsubishi WD-57732 Projection Television
Lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
shaun
Oct 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Replace bulb tv wont turn on
make sure the lamp and lamp door are seated properly. does it blink any codes. 3 blinks is lamp or lamp door not seated properly
Jun 25, 2009 | Sony KDS-60A2020 60" HDTV
I have replaced the lamp.Now the lamp wont come on and tv shutts
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Jan 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Mitsubishi WD-65735 Television Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
