Question about Dell XPS M1730 Laptop
GRRRRRRRRRRRRRRRR! Ok, I'm better now, sorta. Problem: Dell PC XPS 1730 was working wonderful! Worked on it all day, turned it off at night, turned it on in the am. NOTHING! Black screen, and a few click, clicks. Sooo. I replaced the hard drive, and was so proud of my self, because it seemed to fix it! Spent 2 days down loading windows vista and all the up dates! Happy! Went to bed last night with a huge smile on my face! Turned it off. THEN, this morning feeling, oh so proud of my self.... got my coffee, sat down, and turned my PC on. DON'T YOU KNOW I"M BACK TO THE BLACK SCREEN< NO FANS! The lights light up and I'm back to getting the 2 click clicks and nothing. What gives,? Using my back up PC.
    Top Expert:
  • Dell Master
  • 24,773 Answers
Probably a GPU issue. It may need reballing as the solder melts under the IC.
Posted on Mar 28, 2017
  • 163 Answers
SOURCE: Laptop went completely dead
These like to short MOSFET's in the supply line and if Dell wont help yell back weve repaired a ton of them.. Good luck!
(Does the LED on the adapter go out when you plug it into the machine)?
Posted on Jan 18, 2008
  • 1250 Answers
SOURCE: Problem with startup of XPS 1530
try run vista on safe mode
Posted on Nov 27, 2008
SOURCE: Dell inspiron 6400 screen problem
Please run a diags on the system by pressing FN+power button and posts the results. Also try booting to safe mode by pressing F8 when you start the system posts the results, I will be able to definitely help you with this.
Thank you
Dell Laptop Expert
Posted on Jan 09, 2009
  • 1183 Answers
SOURCE: black screen Dell laptop xps vista
the symptom more or less feels like there is a video driver problem on the laptop. I would like you to shut down the sytem ,disconnect the Ac adapter and remove the battery from the system. press the power button for 10 seconds .
Reinsert the battery and connect the Ac adapter.
Press the Fn + Power button , to run the diagnostics.
Do post back if you see colored lines on the screen that i can give you more help
Posted on Apr 05, 2009
  • 5158 Answers
SOURCE: No response when i turn xps on.
the monitor may have been toggled off.... usually this is a function key and another key at the same time. examine the keys for one that looks like a monitor unless you have the manual... it will tell you there how to change it.
Please take a moment to rate this solution
Posted on May 23, 2009
Disable mic on xps m1730
Right click on the speaker icon in the system tray (bottom right, next to the date/time) and select recording devices. It will give you a list of whatever devices you have on your computer that are designated to record sounds. Choose the on board microphone, right click, and select disable device.
Feb 16, 2014 | Dell XPS Computers & Internet
I have an external toshiba 1t 2.5 hard drive with loads od stuff on it but i did a clean install on win 7 now it says i need to format it befor it will see it but if i do this i will loose my data tried...
Use another external Hard Drive temporary.
Download GETDATABACK , install it and run as administrator.
Run the program as to :"recover deleted files".
After doung the 3 stages of scan, your files will appear intact.
Save them to another Hard Disk.
Hope you succeed - it needs patience.
Oct 24, 2013 | Dell XPS 1330 1730 M1210
Both are ok and both perform about the same. The 1730 is the newer of the two. Newer units will pick up further however.
Jul 07, 2013 | DE-1730 Radar Detector
XPS/Dimension 410/9200 Desktop, And Virtual Memory!!!!
you can set your virtual memory as high as 512 depending on what you want to do with your pc are you gamer if so reduce that setting if not and you using it for applications setting it higher will acheive better results.
Jan 26, 2010 | Dell XPS 410 PC Desktop
I have a dell xps 410 i replaced the power supply because it wont turn on still have the same problem,i used a dell just shut down one day now it wont do anything just one yellow light on...
Ok to troubleshoot it, connect the PSU to the MotherBoard ONLY, test, you may find that with it connected to the MB only it doesn't work, remove RAM and check, if PSU still No Go then MB is faulty if OK, add devices, DVD, Hard Drive, one at a time untill you find one that stops the PSU, that is ya faulty bit. replace it.
Why has DELL discontenued this model? Was it
Dell Discontinued them because they bought Alienware and the Alienware M15x and M17x were direct competition. Note the URL ADDRESS in this Link is
Sep 29, 2009 | Computers & Internet
Video Card replacement seemed to cause further problems
Hi again!
Ok, this it the supportsite for your pc:
The only thing is that there isent any mediacenter for that pc, so i thionk its better if you follow this link and enter the TAG number that on you pc, that will take you directly to all software and drivers that came on your pc:
Follow that link, select drivers & downloads, selcet enter the TAG,
Now type the tagnumber that you will find on your pc.
Dell will now give you all the drivers and the uppdates you need, i think a good idea is tho reinjtall the sound drivers, there are drivers for your cd/dvd for downlad also, install the to and se if the cd/dvd works, if it doesent work, take the pc back to the store and tell them that you want them to fic the problems they caused you,
Let me know how it goes M8!
Good luck
May 23, 2009 | Dell XPS 400 Dual Core 2.8Ghz, 512MB,...
Just got a new Dell XPS 1730 Laptop and the Numeric Keypad doesn't work. Yes, the NumLock key is on.... I heard that some newer BIOS has a setting to for this, but I can't find anything in Setup. Any...
hmm, if the numpad is actually a part of the laptop then i suggest you to conact their support line even if its ****. the dell bios is extremely strict and doesnt have many options.
Jul 02, 2008 | Computers & Internet
I bought an advent 7203 pc model number eaa-89 in january this year and whilst using it the other night the screen went black so i thought the battery was flat and put it on charge when i tried to switch...
dont buy advent total **** buy a 2nd hand dell better value less chance of breaking honestly i had two advents both **** one when i lifted the hard disc stopped! cheap **** now i have a shiny dell xps 1 year old warranty extend option if you want build quality night and day im also sitting with a busted 7093 yeah advent boards just burn out nasty cheap conning mothers**
Jun 21, 2008 | Computers & Internet
Dell XPS M1730 Laptop Logo
50 people viewed this question
Alun Cox
