Question about Philips 27RF50S 27" TV
I hooked the ps3 to the philips tv. turned on the ps3, AV1 displays in the corner. Nothing else happens, I am expecting the ps3 logo
    Scholar:
  • 47 Answers
Give this a try...
Leave the TV running, go over to your PS3 and turn it off.
Once its off, hold the power button down till you hear a beep, KEEP HOLDING THE POWER BUTTON till you hear a double beep. The PS3 will shut itself off.
Give the device a couple of seconds, then hit the power button one last time (just turn it on, you don't have to hold it).
If all went right, your baby is back up and running...
Posted on Oct 11, 2010
  • conniepet788 Oct 11, 2010
    Thank you. I took your advice, but it did not work. I tried other combinations of powering off and on the tv and ps3, it is the same result each time. It does work if it is connected using hdmi to a computer screen, but I don't the hdmi adapter for the tv so I am trying it in the regular mode which is giving me the problem
How can I get my Philips TS3259C1 to turn on with AV1 as the channel?
You have to enter its service mode option to make it. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Aug 19, 2012 | Philips TS3259C TV
I have Philips 15PF9945 (15"
If the last problem happened at first, I would blame the power supply since this is a very common point of failure. You have had so many different problems preceding it dying completely, it sounds you should plan on replacing the main board and the power supply. The failures you first had all point to the main board where most of the signal activity processes happen but the fact that it will not even light off now point to what I would call a 'lemon.' If the set is more than 2-3 years old, it may have still been built by Philips but all the newer sets under that name are now built by Funai, the worst Asian manufacturer of all.
Apr 18, 2011 | Philips 15PF9945 15 in. HDTV-Ready LCD...
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    Trying to hook up dvd player to a philips 27ps55-s121. I cant get it to show up on the tv screen. I dont know what channel the tv needs to be on to show the dvd. and i am unsure where what plug (cable)...
    Connect one end of the VIDEO
    (yellow) CABLE to the AV1 in VIDEO
    jack on the back of the TV. Then connect
    one end the AUDIO (red and
    white) CABLES to the AV1 in AUDIO
    L and R(left and right) jacks on the rear
    of the TV. Connect the other end of the cables to the appropriate color on the DVD player (yellow to yellow etc.)
    Press the CH + or – buttons on the
    remote to scroll the channels until AV1
    appears in the upper left corner of the
    TV screen.
    Slide the TV/VCR/ACC switch to
    the VCR position.
    Insert DVD into player and press PLAY.
    Aug 23, 2010 | Philips Televison & Video
    When i turn tv to av1 (where connected) then turn ps3 on the ps3 lights up but nothing happens on the tv I have to pull plug to ps3 and plug in again and turn ps3 on then it works, but this cant be good...
    With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. might be a video setting that is bad.
    Jan 23, 2010 | Sony Playstation 3 (PS3) Console
    My ps3 turns black and nothing happens
    Try checking your HDMI or VGA lead and reset the Ps3 Settings
    Oct 03, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 starts and the green light is on but no image omes up on my
    Try connecting the PS3 to your TV with a scart cable first and go to the appropriate channel. The problem you are facing is probably because the default output is not HD. So you must change it to HD you can do this by going on your PS3 display settings, whilst your operating on standard definition, AV1 or something like that. When the you are on display settings plug the HD cable in the PS3 while still being on AV1 and then plug the cable in, this may prompt a message saying that a HDMI device has been detected and you can change to HD, if this message appears switch to the HDMI output and then select yes and automatic on the PS3 for optimal settings in HD. If the message does not appear then select the HD output yourself after plugging the HDMI cable in and then change to the channel and do the same.
    Jul 20, 2009 | Sony Playstation 3 (PS3) Console
    Sound but no picture on PS3 using AV3/4
    the best configuration is using component AudioVideo cable.component video out from ps3 use 3 wires going to component video input to your tv (Y-Pb-Pr) and two wires for audio left.right. use av1 input on your tv to hook the audio and video. let me know if you still have issue.
    Apr 05, 2009 | Philips Televison & Video
    A humming noise coming from tv when cable and ps3 are hooked up
    I fixed mine by removing the cable wire from my tv. For some reason tv cable and the old PS3's cause a problem.
    Feb 08, 2009 | Sony Playstation 3 (PS3) Console
    Ps3
    Turn on the PS3 and hold the power button down until it beeps. resetting the display settings.
    Mar 03, 2008 | Sony Playstation 3 (PS3) Console
    Philips 27RF50S 27" TV Logo
    124 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
