Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I was cleaning my oven and i am getting an alarm for f90
  • 2,382 Answers
Hi, F90 is usually a faulty Door Lock Motor. A way to try to fix it would be removing , then reapplying power, the door locks should cycle until they detect (by switches) that they are in the open position. If that does not work you may want to check the switch as well as the motor, but It is dangerous voltage in there.If you are handy and safety oriented you may want to pull out the lock motor and have a look at those switches and wiring as it may be stuck/burnt. You may wan't to call a service professional out to look at it. Might run you about $200 for a new motor (parts and labor)
Posted on Oct 11, 2010
  • Save_money7 Nov 21, 2010
    Whirlpool RBS245PDS Electric Single Oven
    I turned off power - circuit breaker - turned power back on - pushed in the door plunger switch at the top right - the lock disengaged - told my wife I fixed it for her... lol
    pressed off/cancel on the control panel - then reset the clock.
Keeps beeping and saying f90
I found this, hope it helps:
F90-Maximum oven door unlock time exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch. 2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary. 3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam. 4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, repl;ace Lock Motor Assembly. 5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly. 6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch. 7. If all situations above do not solve probem, replace EOC.
Oct 25, 2012 | Ovens
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
My frigidaire self cleaning oven says F90?
Lift top - there is a quater inch button on the black box behind the door lock - use screwdriver to press the button in - resets
Sep 17, 2012 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire oven error code
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
7. If all situations above do not solve problem, replace EOC.
Accessories For Audi
Jun 12, 2012 | Ovens
Error code f90 double oven
Hello, Thank You for using FixYa. I will be helping you today. F90 is a failed door lock check the lock switch and check the lock motor if its good replace control.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Frigidaire Ovens
My oven has F90 error message
i contacted kenmore and they them selfs are not sure of the code being displayed is it definitly f90
Jun 25, 2010 | Kenmore 30169 Electric Single Oven
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F90 code flashing and i cant reset it
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Gleb30tsa
find the circuit breaker panel and turn off the one labeled "oven". wait 30 minutes and restart. any luck?
May 31, 2007 | Frigidaire GLEB30T9D Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
257 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
