Question about HP PSC 1210 All-In-One InkJet Printer
How many cords chould the printer have and where do they go?
  • 835 Answers
Two one will go to the power outlet and the other is a usb cord that will go into a usb port on the computer
Posted on Oct 11, 2010
I have a 1992 suzuki bandit gsf 400 bought a new battery started up fine drove 4 days then my battery was completely drained managed to jump it but ran very rough could it be my cdi or regulator i have the...
if you have an volt meter you can check on the batterie ,if he loads.
you chould have somwhere 13 a 14 volt.start your bike and set,
voltmeter on positif red and negatif black you chould read 14.2 v
then trottle up little and the number chould go higher.when you read ,
14.9 means he overload.in that case your regulator.engine turning,
rough because sparkplug dont get the right amount voltage.so the piston will not go strong down by weak spark.and then it will go not,
go up strong.was the new batterie reddy for use.
Jul 26, 2012 | 1992 Suzuki GSF 400 Bandit
I have a lanier 5265 keeps saying paper misfeed
Hello sir; The paper stuck in your paper tray ,I believe in first tray, pull out tray you will find out.
May 02, 2009 | Lanier 1205 Copier
Error code f-51-6
this is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Oct 23, 2008 | Konica Minolta Di1610 Copier
Message H2-00 in sharp ar m207
You have an open Thermistor in the fuser unit or the code is false caused by power surge. To reset it, press P*C* and hit 14 start, then hit either ok or start again and machine chould reboot and clear code. If code returns then the thermistor is bad. You will have to have your local dealer replace either the themistor or the entire fuser unit.
Aug 08, 2008 | Sharp AR-M207 All-In-One Laser Printer
Check Paper size, change paper size casette LTR
It seemed to work, It began after I downloaded a document from the Russian government and translated it in Google.
May 21, 2008 | Canon Office Equipment & Supplies
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
Scan to computer
Had exactly the same problem after I change my router address. Seems windows is not as clever as you'd think! Goto http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000700/000024/faq000724_000.html?reg=us&c=us_ot&lang=en&prod=mfc420cn_us&Cat=14 which is the Brother USA site and they will step you through the fix. Basicaaly you have to go into control panel, select scanner properties and re-browse the scanner connection. Once it has found it again, you chould be back in business. Good luck Tony
Mar 29, 2007 | Brother MFC 420CN All-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
