Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Burners keep arcing even when switched off - GE Profile Spectra JGBP90 Gas Kitchen Range
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Disconnect from power sorce, or flip breaker for oven/stove. Then call GE for a service call.
Posted on Oct 11, 2010
My 30 year old Whirlpool electric stove burners are heating inconsistently, especially the right front. If turned on medium for a while, it will turn red hot. It happens even faster when another burner...
Each burner has its own switch. I suspect your switch on that burner is bad or going bad. Conracts probably burring up from the constant arcing associated with closing and opening. Here is how it works:
Mar 02, 2013 | Whirlpool RF365 Electric Kitchen Range
Burners light but igniters will not stop flashing on some burners but not all
hello,
this usually happens either when the inside of one of the switches arcs from one side to the other leaving the switch opened at all times or if all were lighting I would suspect the spark modulator but your issue sounds like it would be a switch issue which you would have to trace using a multimeter to find out which one is bypassing power even when its set to off you would also have to replace whichever switch is at fault as well if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks again for using fixya Rick
Apr 25, 2011 | General Electric ZGU48N6RHSS / ZGU48L6RHSS...
Solar welder 2175 wire keeps feeding wont stop doesnot arc until trigger is pulled
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Dec 14, 2009 | Welding Tools
Ignitors click and we smell gas, but burners don't light. They will light manually with no problem
Ignitors arcing at the burners? Check to see...you may need to clean the rings around the burner assembly to get a good arc so they will light.
Aug 15, 2009 | Tappan TGF657 Gas Kitchen Range
Igniter on Burners Firing
Located on top each burner control valve is a switch that controls the igniters. One or more of these switches has failed
Dec 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ticking sound of gas igniter continues after off.
try to clean the place wen u remove the control knob,by using a vacium.
Nov 19, 2008 | Cooktops
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Viking Range
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Nov 15, 2007 | Viking VGSC366-6B Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
