Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Tengo un disco externo acomdata modelo HD250UHES-72 ya no quiere arrancar ni subir y tengo todos mis sarchivos en el. Como se puede solucionar?
5 Suggested Answers
zzptichka
  • 95 Answers
SOURCE: Acomdata hard drive Model HD320FES-72
Sounds like the drive has seized spindle... Not good news.
Is it buzzing similar to any of these noises: http://datacent.com/hard_drive_sounds.php ?
What you should do is remove the internal drive from the enclosure and connect it directly to the computer. If still buzzing then it's a real mechanical problem...
Posted on Nov 03, 2008
  • 3 Answers
SOURCE: acomdata HD500uhe5-72 cant be seen . on XP
Try rebooting the computer first with the drive not connected to it.
After the computer reboots, make sure the accomdata is turned off then connect the usb cable. Then turn it on and you should get the password dialog box and be able to access it.
Posted on Apr 21, 2009
  • 109 Answers
SOURCE: Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Posted on Feb 06, 2010
  • 71 Answers
SOURCE: se me cayo mi disco externo y no quiere arrancar
Desafortunadamente no. Los discos son muy sensibles y seguramente se da&o con el golpe.
Posted on Jun 06, 2010
Se me trabo el lente
HOLA A TODO EL MUNDO TENGO UNA SAMSUNG PL-120 SE ME TRABO EL CUBRE LENTE ALGUIEN SABE COMO LO PUEDO SOLUCIONAR?? O DEBO LLEVAR ALGUN SERVICIO TECNICO?
Jun 16, 2012 | Samsung PL120 Digital Camera
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Hitachi Deskstar - modelo HDP725050GLA360 Sata... tengo este modelo de disco lo tengo en ungabinete externo de disco se cayo y ya no lo,lee tampo en una comutadora como puedo salvarlo
Hola que tal, tengo malas noticias, cuando un disco duro se cae lo mas probable es que se dañe, lamentablemente no hay forma de reparar el disco pero sí de extraer la información que está grabada en él, cuesta muchisimo dinero extraer la informacion ya que requiere de equipos y personal calificado para la recuperación, si la información es muy importante y si puedes pagar aproximadamente 600$ por la recuperación el camino a seguir es buscar una empresa de recuperación de datos en tu país.
Lástima darte estas malas noticias...
May 30, 2011 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
Hola, tengo un tv modelo tx-L42D25E y no consigo grabar en un disco duro el disco duro es de 500 G. marca conceptronic. lo he intentado todo.
Tienes que ir a menu, gestion de disco duro (HDD) y all? preparar el disco duro para ser usado con el televisor. El televisor no puede grabar en ningun dispositivo usb que no se haya registrado desde ese menu.
¡A ver si hay suerte!
Apr 08, 2011 | Panasonic Televison & Video
Disco duro externo
Seagate disco duro externo
si estás usando un cable USB la computadora deberia encontrarlo automaticamente, el programa es solo para proporcionarte utilidades.
si quieres recuperar estas funciones puedes bajar varios de estos en el siguiente enlace:
http://www.seagate.com:80/www/es-la/support/
busca tu modelo y baja el programa recomendado de hecho esos los puedes usar el mismo programa para varios modelos
si te sirve la ayuda no olvides darme un rating
gracias
Apr 28, 2010 | Seagate (ST3320820U2-RK) 320 GB USB 2.0...
TENGO UN MITSUBISHI DE 95 , LA TRANSMISION 1.8
quizas necesita revisar sensores de transmision,tambien el nivel de aceite,ya por ultimo quizas sea que ya empezo a resbalarse y va a necesitar una transmision nueva o usada.
Sep 19, 2009 | 1995 Mitsubishi Mirage
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Hola tengo una TV proscan PS27108, Esta bloqueado el canal 00 video y no puedo desbloquearlo, no tengo el control original entro con los controles de la tv pero no me da la opci?²n de desbloquear ese...
parece que tiene un "codigo" para bloquear los canales 3,4 y line-in, trata de dejarlo desconnectado por 24 horas, lo he oido en algun lado!, y se supone que se borre el codigo!
Mar 09, 2009 | Proscan PS27108 TV
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
66 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
