Question about Rockford Fosgate Car Audio & Video
I have a 500 mono. it al of a sudden is shutting off when the bass hits. the green light will flikker and go out but then come back on untill the bass hits again. thoughts?
  • 4,340 Answers
Yes. It sounds like overmodulation, but you did not specify the volume at which the issue appears. usually loud. Check the speaker for correct ohms resistance, if not correct yoru amp will overload and thermally break the circuit, then reset...
Posted on Oct 11, 2010
What are some best cheapest bass amp under 500$?
'Best' and 'Cheapest' are seldom in the same category, but have a read of these links.
12 Best Subwoofer Amplifiers for Your Car or Truck - BestProducts.com
www.bestproducts.com/cars/parts/g662/subwoofer-amplifiers-for-your-car/
  1. Cached
  2. Similar
Jul 19, 2016 - If you want big bass, choosing the right subwoofer is only half the battle. Be the loudest car on the block with the help of these new mono amplifiers for your car or truck. ... 14 Best Rubber Floor Mats for Your Car or Truck.
Best Car Amplifier 2016 ' Top Rated Auto Amplifiers - CarAudioNow
https://www.caraudionow.com/best-car-amplifiers/
  1. Cached
Looking for the Best Car Amplifier of 2016? ... And if you are going to add a subwoofer, a monoblock amp is an absolute necessity. ..... Two-channel A/B ZRX516.2, 500 watts; Four-channel A/B ZRX616.4, 600 watts; Four-channel ... (PCBs) that can perform under the most rigid and extreme conditions attesting to the brand's ...
Bass Packages Under $500 at Crutchfield.com
www.crutchfield.com > ... > Car Audio, Video & GPS > Car Subwoofers & Boxes
  1. Cached
Under $500 - Shop for Bass Packages with the help of real A/V experts. ... package includes Magna Bass MB212P mono amplifier (250 watts x 1 at 4 ohms) and ...
Can you guys recommend me a combo amp under $500? ' TalkBass.com
https://www.talkbass.com > ... > General Forums [BG] > Amps and Cabs [BG]
  1. Cached
Jan 19, 2012 - Hey guys, I'm currently in middleschool and I need a new amp thats preferably 400-500 watts, but under $500. We currently have a bassist, ...
Need good advice on a sub+amp combo, $500ish budget - Car Audio ...
www.caraudio.com > Forum > Car Audio Discussion > Subwoofers
  1. Cached
  2. Similar
Oct 13, 2012 - 12 posts - ‎1 author I'm new to both the forum and somewhat new to car audio in general so please excuse any ... So i need a great sub and amp to complement them for around $500. ..... other subs for under 200 bucks id rther have over type r
World Record Budget Build w/ Drew Wesley's $500 Car Audio System ...
z? 2:32 https://www.youtube.com/watch?v=NOatL_DzZL0
  1. Similar
Oct 3, 2013 - Uploaded by EXOabigdeal World Record Budget Build w/ Drew Wesley's $500 Car Audio System ' 4 12" VVME Subs & Bass Amps ...
Top 10 Best Car Amplifiers To Buy for 2016 - MyCarNeedsThis
mycarneedsthis.com/todays-best-car-amplifiers/
  1. Cached
Whether you're looking for an amplifier to power your entire cars component speaker ... power outputs come in 3 settings (of 800 watts, 500 wats, and 300 watts ). ... Rockford Fosgate R750-10 Class D 4-Channel Subwoofer Amplifier ... Talk about power when it comes to getting some serious knocking under the trunk.
Oct 30, 2016 | Car Audio & Video
Amp shuts off.
check the connection of power connection and the remote connection tone amp,you can check also you inside by using your hand ,turn on the amp and wiggle it the power connection parts.
Jun 15, 2013 | Jl Audio 500/1 Car Audio Amplifier
I have a 500/1 mono jl audio amp and two w3 10" woofers, every time my bass hits hard my low ohm light will flicker on and off but the light doesn't stay on to long it only flickers every time the bass...
not really a problem, your just running a the threshold of the amps comfort zone, a lil trick to raise your impedance a little bit its to run an additional 10 feet of wire before your sub, (longer the wire the more resistance) 10 feet should jump you up about .5 ohms. you wont hear the difference but your amp will fill it, and run a little better. 20 feet will give you right around 1 ohm. now if you dont mind loosing some power run the subs in series and then run them bridged. your amp will work harder, but run easier because its on a big open loop. but before all this take a multi meet and read out your voice coils to see what the ohm level is, then read out what it is at the speaker, then you will see 1. if the subs are okay, and 2. how much you need to raise your impedance for you amp to run comfortably.
Aug 09, 2010 | Jl Audio 500/1 Car Audio Amplifier
Protect Light problem
I'm having the same problemdid you ever figure out what it was ?
Dec 01, 2009 | Hifonics Car Audio & Video
If i turn dvd on it says LOADING and keeps flikkering
try to format your hard disc or to reinstall the operating system
Mar 24, 2009 | JVC DRMH50 DVD Recorder
Green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Mar 16, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Amp problem, need help!!!
Sounds like one of two problems: either your subs are beginning or have gone bad, or you amp is going bad. What size power and ground wire are you using? You should be using at least a 4 gauge for both. Also what impedence are you running with the amp, ie; 4ohm mono, 2ohms stereo, etc?
Jun 19, 2008 | Phoenix Gold Octane-R 4.0:2 Car Audio...
When I record from my Bass..I hear Mono only
unless you bass is a stero model... and there are only very few out there that are, then you may be using channel setup for stereo use. change it back to a monochannel. but be sure that you also have the output of that channel panned to the center or you will always have left or right output only. Or mono as I assume you are desribing. Hit me back if you want to know more about it.
regards
Graeme
Jan 26, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Car Audio & Video Logo
192 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
