Question about Xerox Phaser 6100/BD Laser Printer
Laser color printers
I can not get a straight answer from anyone.
Can you tell me what color laser printer is good for printing transfer paper for T-shirts and coffee cups? I have a Xerox Phaser 6120.
Thanx for any help. Gene
  • ursena May 31, 2008
    I thank you very much for your help and was helpful, you might be right about the 6120, it's just when I tried it with laser transfer paper, it melted it to the roller, likewise, the HP 2600.
    President:
  • 2,072 Answers
I know the phaser 7400, 7700, 7750 and 7760 are usable with transfer paper, as well as the larger platforms such as the 250.
I have thought that the 6120 can be used for that. It has a fuser, and most every product that uses a fusing type ink should be able to use transfer paper.
Posted on May 31, 2008
  • Rick Kasper May 31, 2008
    Have you looked at the xerox.com site to see if there is a recommended transfer paper they make ?
    I have had customers in the past that used those printers for transfers and I am certain Xerox makes a specific transfer paper for that purpose.
    Look at Xerox.com under the media types they sell.
Colored stripe down the edge
Sounds like the transfer belt could be bad, however if your lines are just 1 color than replace that color toner cartridge
Aug 05, 2012 | Brother HL3075CW - HL-3075CW Wireless...
Tip
How to Differentiate Between Laser Printers & Inkjet Printers
You require a new printer but you do not know whether to buy an inkjet or a laser printer, as you are not aware of the differences between the two. Each user or organisation is faced with the dilemma while buying a new printer. Most customers operate under strict budgetary constraints and it is only normal to consider initial purchase costs and space limitations. However, it is prudent to take into consideration the long-term operating costs associated with the particular printer.<br /> The choice of printer will, largely, depend on your requirements. Inkjet printers are usually ideal for home users who have limited text and photo printing needs. Laser printers are better suited to larger office environments with high-volume and high-quality printing requirements.<br /> The differences between a laser and an inkjet printer are generally categorised into a few broad segments, namely, cost (initial and maintenance), speed, quality, space and networking facilities. It is also essential to understand the technology behind the manufacturing of the laser toners and ink cartridges as this is a major contributing factor towards the cost.<br /> <b>Difference in Technology & Networking Facilities between Inkjet and Laser Printers</b> -<br /> The technology used for inkjet cartridges is simpler and the parts are less expensive than the laser toners. The black inkjet cartridge has only black ink. The color inkjet printer contains two main ink cartridges, for black and other primary colors respectively. The primary colors are then divided into three compartments for cyan, magenta and yellow ink. The primary colors are consequently mixed to produce all other colors. The cartridge contains a reservoir which has compartments with metal plates and a number of tiny nozzles on the print head of the cartridge. The number of holes or nozzles depends on the resolution of the printer. It is usually 21 - 128 nozzles per color. The ink gets heated, when the current starts flowing through the metal plates, after the print command is given. The heat causes vapor bubbles to form inside the cartridge and make the ink swell up. The ink then flows out in droplets from the nozzles onto the paper in a few milliseconds. A vacuum is created (once the ink droplet flows out) which draws more ink into the nozzles ensuring a steady supply of droplets as required. This common technique is called Thermal Inkjet and the coinage of the name 'BubbleJets' by Canon has been due to the bubbling vapors.<br /> The Laser toners use a more elaborate and complex technology. A powder called Toner is used by laser printers, fax machines and photocopiers to print text and images on laser and photo paper. Initially carbon powder was used but now manufacturers use disposable cartridges which can sometimes be refilled. For the laser toners, individual carbon particles are mixed in a polymer which melt in heat. This binds to the fibers in the paper. The laser printers consist of the printer toner and the drum. The positively charged toner gets attracted to the negatively charged drum. The toner is transferred to the paper by the drum. The toner contains special wax that melts and dries in milliseconds. When the toner is transferred, the fuser applies heat and pressure to make a durable image. The fuser system is made up of the hot-roll and the back-up roller.<br /> The high-end laser printers generally come with networking facilities for you to connect to your computer network directly. This cuts down additional costs associated with networking, as is the case with ink printers. The ink printers cannot be linked to a network directly. Networking has to be via a computer, therefore more expensive.<br /> The laser printers are larger in size than the inkjet printers. The latter is, therefore, space saving and ideal for the home and small office users.<br /> <b>Difference of Quality & Color between Laser and Inkjet Printers</b> -<br /> Since Inkjet Printers spill out tiny droplets of ink to print, the resolution is lower than the laser printers. Laser Printers printer better quality text, as their resolution is higher. High resolution also helps the laser printers create precise fonts without fuzzy edges. However, the cost-effective inkjet printers are usually recommended for inexpensive color printing. These can print high quality text, large photo prints, graphics, banners and greeting cards at less than half the price of a color laser printer. Nevertheless, it should also be seen if the cost of ink and paper suits your maintenance budget. Laser printers are capable of producing good quality prints on all kinds of printing paper but the inkjet printers will require inkjet paper to produce good quality prints without any fuzzy edge brought about by 'bleeding'.<br /> <b>Difference in Speed between Ink and Laser Printers</b> -<br /> If laser printers lose out to their inkjet counterparts on account of price, they are way ahead when it comes to speed of printing. Users who need large volumes of printing also prefer the laser printers. Laser printers are more suited to general office use than the inkjets. The least expensive laser printer can print around 10 to 15 pages per minute. The inkjets are usually rated on the speed of draft or quick printing mode, which is suitable only for proofreading purposes. The HP Deskjet 5650, which is a fast color inkjet printer, prints at a speed of 21 ppm Black, 15 ppm Color in the draft mode. However, the speed drops considerably when high quality black text is printed and it also takes longer to print a letter-sized quality photo.
on Nov 10, 2010 | Office Equipment & Supplies
I have a HP Color laser jet 2600n printer. I have tried different Glossy paper, marked for laser jet, but still get bad smudges on my prints. these smudges are still visible on the next ordinary prints...
You need to ensure that you are telling the printer that and your print driver that you are using glossy paper as this will change the speed that the printer prints at and ensure better bonding.
May 23, 2011 | HP Color LaserJet 2600n Printer
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
Paper feed not straight straight therefore printing an angle
it is problem transfer roller clean it then solve your problem
Nov 21, 2009 | Samsung CLP 300 Laser Printer
Color photos come out awful!
I can only hazard a guess but it sounds like your photo paper is not absorbing the ink correctly or the ink does not have time to dry before the next page comes out
As for transfer to next page do you mean when the next one comes out and drops on the first or as it is going through the printer.
If it is after it comes out then you may want to print one at a time and take them off the printer before the next one comes out and place it where it can dry.
Photos do take a little longer to dry than regular paper.
This may be the cause
Aug 21, 2009 | Ricoh SP C220N Aficio Laser Printer
Trying to print on laser photo transfer paper, but printer seems to be too hot for it - is there any way to print on this transfer paper?
i tried to print on laser paper too but fuser is too hot. its melting the paper and getting jammed right? i got tired of printing on laser paper and converted to inkjet paper. this is much easier
Jul 14, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
Ghosting on my laser printer
You just need to run more print outs to clear the ghosting.
Apr 10, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Printing is crooked
if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
200 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
