Question about Symantec WinFax Pro 10.0 for PC
I have problem abut my Computer at keyboard not function typing and not function press keyboard, and I don't know function run, don't open my documents file it respond say error. please give me manual to me sir.
    Problem Solver:
  • 23 Answers
Please solve the victim software counterfieting
Posted on Oct 11, 2010
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    CAP LIGHT DOES NOT COME ON
    Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
    Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
    b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
    Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
    Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
    Jan 21, 2013 | Acer Computers & Internet
    How to tell if caps lock is on
    Some keyboards will have a light that goes on when caps lock is turned on
    Type the following:
    "Scancode Map"=-
    Hope this helps
    Nov 05, 2012 | Computers & Internet
    Hi There, Can a Dell desktop power on with out a keyboard?I think my keyboard is malfunctioned so my PC keeps entering power safe mode at start up. Please advise on what i should do or a solution to this...
    I have the same desktop, which I use as a media center. The computer, by default, requires that a keyboard be connected in order for it to power up normally. Although you can defeat this function, ironically, you need a keyboard to do it. A replacement keyboard can be found just about anywhere for $10 or less, so don't despair. Just find a keyboard with the same type of connector (or a provided adapter of the right type), and you're back in business! (I bought my replacement at Big Lots for $4 but you can find them from any office supply store, Radio Shack, or a computer store.)
    Jul 05, 2011 | Dell OptiPlex GX520 PC Desktop
    I pressed some keys on the computer and now when I use the computer keyboard when I type o I get the number 6 and when I time i Iget the number 5. what did I do I am using a different keyboard as I type...
    Hi Carol,
    It seems that the function key (Fn) on the bottom left of the keyboard is stuck or jam. Try hitting the key multiple times or raise it with your fingers. Then try to press I and O again. Below the is image of the key you need to press and clear the jam from. You can also pat the keyboard/ laptop from at the bottom in case the jam wont clear by pressing the key.
    Fig 1 : The function key
    Fig 2 : The the shown below have multiple icon, those are activated by pressing Fn (function key)
    Regards,
    Shrey
    Jun 04, 2011 | Acer NSK8458AN Keyboard
    Maual for compaq keyboard
    well there are many key on keyboard and every key has its own function so for this type of guidance or free technical support regarding computer you can visit----http://techbuddies-robin.blogspot.com/
    Jun 06, 2009 | HP Compaq Motherboard
    Hot Keys
    Follow this procedure to enable the special buttons or function keys on the computer or keyboard in the Microsoft® Windows® XP operating system.
    IMPORTANT:
    • If software has been installed for use with a third-party keyboard or mouse, uninstall the software to ensure there are no conflicts.
    • On AMD™ or Transmeta™ processor-based computers, the function keys are hardware controlled and not controlled by a hot-key utility.
    NOTES:
    • The volume button, brightness key, and disc eject button on some computers will not work if the HotKey Utility application is not running.
    • The Magnify button and the Fn keys will not function properly before the operating system has finished starting.
    • The setting may not be saved if the ESC key is used to close the Fn display. Press the ENTER key or allow the Fn display to close automatically to save the setting.
    1. Click the Start button, then click Run .
    2. In the Run window, next to Open , type MSCONFIG .
    3. Press the ENTER key.
    4. In the System Configuration Utility window, click the Startup tab.
    5. On the Startup tab, under Startup Item , ensure that there is a check in the HKserv checkbox. NOTE: If HKserv is missing, reinstall the HotKey Utility application and the Sony Utilities Library.
    6. Click the OK button.
    7. In the System Configuration box, click the restart button.
    Nov 13, 2008 | Sony VAIO VGN-S460 Notebook
    Keyboard locked in upper case
    Try reseating the key board.
    Check whether the keys are stuck especially the shift,alt,caps lock.
    Hav you spilled any liquid on the keyboad.
    Try uninstalling any software you installed for the keyboard and remove it from Device Manager (Click Start-Run-Type devmgmt.msc and click OK).
    Reboot and see if that helps anything. Also, check the right shift and make sure it isn't stuck and check the keyboard settings in the Control Panel
    Update the keyboad software from the microsoft website.
    Pleae mntion the model  number of the keyboard to help us know more about the keyboard.
    You can try holding down function key and press f11.
    Control Panel -> Regional and language settings -> Tab: Languages,
    Button: Details, and add a US Keyboard.
    Check this to know the functions
    http://support.microsoft.com/default.aspx?scid=kb%3ben-us%3b894513
    Check the keyboard settings.
    Try using other keyboard to know the keyboard is fine or not.
    This will help you i hope.
    Good Luck.
    Live, Love, Laugh.
    May 06, 2008 | Microsoft Windows XP Home Edition
    When I type a 5 it puts 5/ and it opens Internet Explorer by itself
    Try pressing the Num Lk (number lock) button, if that doesn't work try pressing the Num Lk or scroll lock button while holding the Fn (function) button
    Jan 15, 2008 | Microsoft Natural Ergonomic 4000
    Symantec WinFax Pro 10.0 for PC Logo
    35 people viewed this question
    Top Symantec Computers & Internet Experts
    Tony
    Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
