Question about HP Computers & Internet
My desktop turns on but no display on the monitor
    President:
  • 1,768 Answers
1. If you have another monitor try connect it to the VGA port and see if you get a
screen/ if "yes" then your monitor is in need of repair.
2. If "no" then you either have the resolution for your monitor set to high for the display and will need to set it to the proper screen resolution.
3. check the VGA or DVI cable to see if it is seated to the video card properly.
4. Check the VGA/ DVI cable for bent or broken pins.
I hope this helps. Have a great day!
Posted on Oct 11, 2010
Dimension 4600 no display turn on. HD spins lights lite and can turn off no bios screen display
Change the VGA cable from the monitor, first but sounds like it's the video card that's failed. I would check the monitor with another computer to make sure it's not that.
Jun 03, 2014 | Dell Dimension 4600 PC Desktop
Monitor is in slef adjust mode how can i turn it off
Trussell43,
System setup Disks do not have any relation to your Monitor unless it is an All-In-One PC or a Laptop.
If you can see display when the unit is booting, but not when Windows should be displaying the Desktop, then your Display Size has been set outside of the size limits or refresh rate of the monitor.
An IT Technician could help you boot the PC in Safe Mode to remove the Monitor and let it re-install. This should forward the instructions to Windows to re-detect the monitor and the display limits it has.
If you have no display at any period, try another monitor.
I hope this helps.
Nov 13, 2012 | Dell Dimension 2400 PC Desktop
I somehow turned off the monitor and I do not know how I have turned on him, now I'm only on safe mode I need help
Go to control panel and click on display.Then click on change display settings.Then click on detect monitor tab.This will tell you which monitor is active.You want monitor number one.This is so you can run two monitors at once or a laptop with a broken screen.This pertains to a win 7 PC.
May 07, 2011 | Acer Aspire Z5700 PC Desktop
When I turn my PC on you can hear it come on but the screen is black.
It sounds like you might have a problem with your video card. If you turn it on and see nothing, not even the gateway logo, than you either have a video card issue or a monitor issue. Hook up the mahine to another monitor to test.
Jan 04, 2011 | Gateway Computers & Internet
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    When i turn on my monitor it shows my desktop then shuts off after 10 seconds...never stays on
    elainenemeth, Hi, Tell me more! How old is this LCD monitor? Is it out of warranty? Did the "SHUT-DOWN-IMMEDIATE" problem occur without warning? Did the BenQ display a "perfect" image the day before? Did you actually count----1001, 1002----1010 and then it shut down, after pushing the monitor on button. Did you do the "flashlight" test? With monitor connected to a "known-good", fully booted pc with Win Desktop displayed, TURN ON the monitor! Did it display the desktop for 1-2-10 seconds ? What did you see or not see when you pointed the flashlight at different angles about 1-2" inches from the now dark (black) screen? Get back to me with your results. I will offer the best advice possible to you as a consumer/user of LCD/FPD monitor. I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
    Apr 17, 2009 | BenQ FP71G 17" LCD Monitor
    Extended desktop rotated, can't turn back.
    Click on the extended monitor which is out of sync with the main monitor and click CTRL + ALT + UP
    Thanks,
    Vasu
    Oct 02, 2008 | Microsoft Windows XP Home Edition
    Monitor not coming up
    try unplugging the monitor cable from the computer and check if you get a power on self test displayed
    if yes then the monitor is fine we have to troubleshoot the computer
    and if nothing is displayed the monitor needs to be replaced.
    Jun 05, 2008 | Dell OptiPlex GX260 PC Desktop
    HP desktop monitor problem
    hi try this ,,,
    1. Ensure the video cable is connected (and connected to the correct video port).
    2. Turn off the monitor using the monitor's power button and then restart the monitor.
    3. Cycle the power on the monitor as follows:
    4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
    5. Unplug the power cord.
    6. Wait 5 seconds.
    7. Plug in the power cord.
    8. Press the power button on the monitor to turn on the monitor. One of two things happens:
      1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
      2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
      3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
        • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
        • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
        hope it will work for u .. little_angel
    Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    Computers & Internet Logo
    142 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
