Question about Video Game Consoles & Games
Belkin PC-DVD to TV Cable Kit, with S-Video Cable & Scart Adapter 10m
Where do you plug it in
  • mukesh_sak Jan 07, 2009
    I have connected everythig to my Laptop and the TV.. but still nothing appearing on the TV
    Problem Solver:
  • 8 Answers
Did you set up your computer for multiple displays? I have rca style cables running from my computer to the TV in the living room so I can watch stuff, but I have to configure my video for multiple displays and select the TV to get a picture.
Posted on Aug 21, 2010
How do I connect a dvd player to tv with no scart connection
Make and model of TV would help.
Very odd TV with no SCART and only a single HDMI. You sure it's not a computer monitor? happy.gif
If the TV really does not have any sort of analogue input you will either need to buy a disk player with HDMI or an analogue to digital converter (the former may well be cheaper!), And if there is only a single HDMI you can but switches to expand the number of HDMI inputs if necessary.
User manual here
http://documents.knowhow.com/TV-Home...nal_120524.pdf
Refer to page 15 which states:
"Use a included SCART adapter cable to connect
between the TV's SCART input socket and a SCART
cable to an external AV device's SCART output socket."
Dec 12, 2014 | Televison & Video
How do I get the correctly connect from the DVD player to the TV set?
It depends on your TV's available inputs. If your TV has an HDMI port, you'll get the audio and HD video to your set with one cable if you invest in an HDMI cable; purchase the cable online (you don't need to pay $$$$ for the cable). Stores that specialize in cables will have the best picture. Press the HDMI select button on your remote to go through the resolution options for the DVD player. (see page 14 of the manual
If your TV doesn't have an HDMI port, check for component video. This will also give an HD picture to the TV. You'll need cables for the 2 RCA audio and 3 RCA (Red, blue, green) video plugs (or one cable with 5 RCA plugs) on each end of the cable. The mega-cables though can be a bit more difficult to plug in. Make sure that the colors match. (Some TVs use an adapter that consolidate the cable connection at the TV. You still need to match the colors at the adapter.)
If your TV only has composite in, you'll have an SD signal at the TV. This is the cable with one RCA plug (yellow) for video and the 2 RCA plugs (red and white) for audio. This cable is often included with the DVD player.
If your TV only has a coax connection (OTA tuner or analog cable), you'll need a Composite to RF converter. These used to be available at Radio Shack and can still be found online as well.
If some countries, the TV might have a SCART port. You can find a composite to SCART adapter.
The manual is available from Toshiba here: http://support.toshiba.com/support/modelHome?freeText=2805086 . Select the Manuals and Specs tab. The file is a PDF; so you will need Adobe Reader or a similar program to read the file.
I hope this helps. If you need additional assistance, please add a comment with details of your TV.
(if your TV has an SD (480i) resolution, you probably only have the composite and coax inputs.)
May 08, 2013 | Toshiba SD7300 DVD Player
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
Connecting Alba DVD to Toshiba TV
If the TV has the red, white and yellow sockets on it you can use an adapter. It's a scart plug on one end (for the DVD player) and 3 little round sockets on the other, usually red, white and yellow, sometimes red, black and yellow, like this:Amazon.
Then you need an audio/video lead with red, white and yellow plugs on both ends like this:Amazon
Or one of these:Amazon
You could also use a multi socket scart adapter to add more scarts to your TV:Amazon
Jan 23, 2012 | Toshiba Televison & Video
How do I connect a DVD player which has a scart that does not fit in new televiosion - connections to large & i can't find a connection on back of TV
Hi, I recommend that buy an SCART to RCA/S-video adapter and use that one connection..
here is an example of SCART TO COMPONENT & S-VIDEO adapter on the URL below..
you can have a cable that one end SCART and the other end whatever you have on the TV..
check on eBay..
http://cgi.ebay.com/SCART-COMPONENT-AND-S-VIDEO-/140482348595?pt=LH_DefaultDomain_0&hash=item20b5668633
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Apr 01, 2011 | Samsung UE37B6000 37 in. HDTV-Ready LED TV
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
Connecting my iPod and my DVD player to the TV at the same time
you can buy scart splitters to give you extra scart sockets and leave the cables plugged in or if you have 3 phono connecters (red/white/yellow) on the side or front, connect to that.
Mar 05, 2010 | Televison & Video
Proscan PS8682P dvd player. It has been over a
so you have two problems: how to connect to (ex: tv),so for this. the cable box has a scart port? if so use a scart/rca adapter available on the market, use on VCR out (Cable Box) and select IN the adapter to IN/OUT switch. and connect to dvd player. The other Scart Port labeled TV connect to TV set with a scart cable. Now u can see tv, and switch automatic to dvd if DVD is on.
The Bad Disc error is a Laser DVD lens defective, needs to be replaced, send to repair.
Dec 28, 2009 | Proscan PS8682P
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
Video game consoles
FARST cheng the scart cable & conecting this cable the ander playsation .Iths posibal the cable no good
May 25, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Video Game Consoles & Games Logo
319 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
