Question about Fisher and Paykel Washing Machines
I have recently got a FP wahing machine but it only seems to have cold water Is that right?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Turn the hot tap off and remove the hot hose at the machine end.Now put the end of the hose into a bucket and turn the tap on to check if you are getting any water out of the hose.Also check where the hose came off the machine the little filter for blockages.Now if every thing is normal refit the hose and turn on the tap.Select a hot fill and then reply back and let me know what happens.Then I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 11, 2010
FP WH60F60W1 front loader. Why doesn't it warm water?
The mixing valve relies on both hot and cold inputs to set the correct washing temperature.
Jun 06, 2015 | Washing Machines
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Mar 15, 2011 | LG Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Foul smell comes from my zanussi jet system washing maching, so bad now that wahing smells of sewerage \r\nhelp please! i have a mountain of washing to do
Have u moved anything recently? the outlet hose must be above the sink waste outlet other wise water from the sink will go into machine
Jun 11, 2010 | Washing Machines
My White Westinghouse 833ES never stops filling, it seems like as water goes in, it is draining right out. Any ideas of what to check would be appreciated. Thank you.
you have to have the drain higher than the water level of the wahing machine, plus ther is no stopper for the water so if you have the drain hose connected directly to another hose and there is no air gap at the top it will just siphon out
Aug 11, 2009 | Westinghouse Washing Machines
Cold water knob is not working
Check the screen on the cold valve. If power is getting to the valve and the screens are clean then the coil is bad. Check continuity if you have a meter.
eric
Jul 01, 2009 | Washing Machines
FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Mar 30, 2009 | Fisher Paykel EcoSmart GWL15
Wahing machine will adjitate only
check your lid switch and check your cold water inlet
Nov 25, 2008 | Kenmore Washing Machines
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Wahing mahine
Suspect water valve is faulty and possible a faulty lid switch.
Dec 13, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
