Question about Amana LEA11 Dryer
Amana dryer will not heat. Exhaust duct is clean. Suggestions?
  • Amana Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Posted on Oct 11, 2010
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Amana gas dryer LG8319W/L2
try getting a lint trap brush its long so u can get all the way down in the trap try cleaning that first that is usally the problem
Nov 17, 2011 | Amana Dryers
My Amana Electric Dryer will not heat up. Model# LE8317W2. We have cleaned out the machine and the vent. I will be purching a heater element (as recommended) is that easy to replace? IS there anything else...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.Here is a video for the element replacement.Here is a video for the thermostat replacement.
Nov 26, 2010 | Amana Dryers
DRYER WILL NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Make sure that the lint filter and exhaust duct is clean.
Good Luck and have a nice day.
Rating the solution is highly appreciated
Jun 26, 2010 | Amana Dryers
Our dryer is running but it is not heating up
Check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is just inside the rear of the dryer usually attached to or near the exhaust duct. Both components can be checked for continuity using a multimeter or ohmmeter. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Aug 29, 2009 | Amana Dryers
Dryer heat output is 148, but takes several runs to dry clothes
You most likely have a ventilation problem somewhere in your exhaust line. This can be very dangerous and a fire risk. You need to do a thorough check of your vent pipe and make sure it is clear and the exterior trap door is working freely.
Jan 26, 2009 | Amana ALE643RB Electric Dryer
Overheating dryer
blowing when the tube is off usually = dryer fan ok, and is a sign that the duct is blocked past that point,
most commonly there is a blockage in the vent hood, the screen that keeps bugs and rodents from gralling up the exhaust, is also very good for catching any lint that squeezes past the lint filter.
most exterior hoods can rmove the screen for cleaning
any flexible ducting is a likely ara as well, the corrugations make a lint trap
check also that the duct from the heater element into the drum is not dislocated or blocked
Oct 23, 2008 | Amana Dryers
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
147 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
