Question about Canon iR 2016i Black and White Copier
Canon ir2016 pick -up roller fail to turn intermittently.
    Guru:
  • Canon Master
  • 452 Answers
Hi you should verify the solenoid of the paper take up Is it correct ? else you must change it.
Posted on Oct 11, 2010
My canon ir2016 copier comes with blank paper when printing and the paper jamed before it reaches the paper pick up roller
Check very carefully it sounds like something small is caught in the paper path, probably a small piece of paper.
Dec 11, 2014 | Canon Office Equipment & Supplies
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
Canon ir2016
Try this. Remove all the paper from trays and inspect for paper in corners or stuck under rollers.
If possible, give it a good blowout. and re-assamble.
May 07, 2014 | Office Equipment & Supplies
Hello My machine is Canon iR2016 and i have problem with Paper Jam. I have problem when I copying more then one copy and i got a problem sometimes in the first 10 copys, sometime at 20th copy... Error...
so, first, did you clean the vertical path roller? ( its a axis with two rollers beneath the paper registration sensor )
Second, when you open left cover, and paper guide plastic cover ( black ) there is also sensor flapper, that can be a quite of pain because slow reaction of spring on it. Apply wd40 on its spring and in left corner where he lays into bushing. To check flapper response, manually close the paper guide plastic, the sensor must be in middle position.
Also it can be the problem in paper pick up clutch and it needs to be cleaned or replaced.
But, also the problem can be separation claws in cassette ( metal claws that holds the paper ). From experience, the probably is sensor flapper or pick up clutch the problem.
Hope that helps!
If you need service manual or help, write on emma.servis@gmail.com
Jun 18, 2011 | Canon iR 2016i Black and White Copier
Our Canon IR2016 after 10-15 paper print, then it stopping printing while I order to print, It appears "change papersize tray:a4" and red light flashing, thanks for your help
I wrote, some kind of the tip regarding these problem. Probably it wont help you much, but you can start to clean the paper pick up rollers and axis, try to remove the paper lint,by blowing her out and apply some wd40, or call service to replace parts with new ones.
http://www.fixya.com/support/r8933657-incorrect_paper_size_while_copy_in
Regards!
Apr 12, 2011 | Canon MF3110 All-In-One Laser Printer
Corona
No it has no corona like analog machine.It has a charge roller in drum unite upper .
Apr 13, 2010 | Canon iR 2016i Black and White Copier
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
White stirkes in canon iR2016 photocopying result
It is either the drum unit or developer unit or transfer roller. if your counter is 150 000 copies change dev unit and transfere roller.
Oct 03, 2009 | Canon iR 2016i Black and White Copier
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
Canon iR 2016i Black and White Copier Logo
103 people viewed this question
old marine
old marine
