Question about Fisher and Paykel GWL11 Top Load Washer
Need to replace the lid on fisher&paykel washing machine
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.To remove your old lid open it and then lift the lid straight up away from the machine.It is only clipped in place.Then refit the new lid by clipping it back in the side holders.Hope this helps and please reply for further assistance.Looking forward to your reply.
Posted on Oct 11, 2010
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Fisher paykel 5.0 smartdrive washine machine
No reset button in these machines.
Check your lid switch & display board for corrosion.
Apr 20, 2013 | Fisher and Paykel Washing Machines
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
My fisher & paykel washer wont start it beeps and says the lid isnt closed, but it is and there is a little ambulance that comes on the screen
I believe the lid switch is faulty, for the later modules the microswitch is mounted inside the door lock mechanism, others under the lid/top left side.
The ambulance is just saying to call for help....
May 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
May 30, 2010 | Fisher and Paykel Washing Machines
Machine won't start
Hi there
i'm not sure if the fisher and paykel machines are any different in new zealand compared to where you live, but the only thing i can think of if it isn't displaying a fault code is if this machine is fitted with a reed switch(these make sure the machine stops if the lid is opened during operation) this may be faulty and staying open causing the machine to stop when the lid is closed. Hope this helps.
Jul 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel machine locked but lid is up
It sounds like the lid lock is either stuck or broken,You will need to lift the top hob by removing the two plastic lugs where the lid rests & removeing the screws it will then lift up and you will be able to remove the lock to inspect it,Also you can remove the lid in the up position by pulling vertically to make it a bit easier,Hope this helps Cheers.
May 21, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher and Paykel GWL11 Top Load Washer Logo
153 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
