Question about Vivitek V37655 56" DLP TV
The bulb is less than 2 years old and it has been flickering for past six months. we always have to turn it off then wait 20 minuets or so then turn it back on. What is the problem? And can you help us?
  • 1,476 Answers
Zimmer3,
It sounds like you have a bad color wheel. It is not running the proper speed and causing the flickering. Usually you hear a humming sound also but not always.
I have a tip at http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv which explains how to change the color wheel and where to get the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 11, 2010
Lights flicker in circuit with dimmer switch
Dimmer gone bad.
Buy new dimmer.
Check total wattage of bulbs, and compare with watt rating of dimmer.
Check if dimmer feels warm
reduce watts in ceiling linghts
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 26, 2013 | Electrical Supplies
Bulbs keep blowing
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Mar 25, 2013 | Mitsubishi WD-65731 65" HDTV
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Our monitor (less than six month old) won't power up.
This is 2005 model, 3 year warranty. 6 months old?
http://www.amazon.co.uk/LG-Electronics-L1915S-LCD-Monitor/dp/B00076V8TY
You will need to open it up, first thing to look will capacitors int ehpower supply, main AC fuse.
http://s807.photobucket.com/home/budm/allalbums
Please verify if it is only six month old, otherwise, take it back to where you get it from.
Apr 06, 2010 | LG L1915S 19" LCD Monitor
1997 chevy blazer s10 cranks but wont start
You have a new battery and it cranks. Turning over is cranking. You are saying it won't start after sitting for six months? What is an old mechanic? Was the cable installed at home during the one year layoff? It sounds as though you failed to hold the old mechanic responsible for installing the correct cable or adjusting the one you have ,so it will start. You have a safety switch issue by the sound of it. Make sure you have the right cable and then find out how to install and if applicable,adjust properly
Feb 07, 2010 | 1997 Chevrolet Blazer
Less than 24 months old. Power up, has 3
sorry to say but your LCD panel is failing, and will have to be replaced sonys panels are expensive
Dec 05, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Liesegang dv 560 flex projector with a pulsating image
Ordered a new lamp at dealers cost ($140). Let's see if it was a malfunctioning bulb.
Oct 08, 2009 | Liesegang dv 560 flex LCD Projector
Vivitek V37655 56" DLP TV Logo
112 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
