Question about Kenmore Refrigerators
Ice maker was running but not freezing water pouring out of freezer flooding kitchen
    President:
  • 1,891 Answers
Water valve is not shutting of . replace to correct the problem .. .. hope this helps mm
Posted on Oct 11, 2010
Tfx25ppbb. Water leaks into bottom of freezer when refilling ice tray in automatic ice maker. Ice still gets made but water leaks to the bottom of freezer. When enough freezes, it leaks out the door
It's probably not the ice-maker. It has a plugged drain. This is located in the back wall of the freezer near the bottom. remove the evaporator cover...(the back wall of the freezer). Below the coils is a trough with a hole in it where the defrost water drains. This is probably frozen over.
Pour some hot water in to trough until you see drain hole. Keep pouring until water runs thru drain. May have to shut down ref to get it to defrost.
Oct 20, 2014 | Refrigerators
Freezer flooding from ice maker
I've maker solenoid not allowing refrigerant to fill evaporator so water can't freeze on it to make the ice
Jan 05, 2014 | Maytag Refrigerators
Our kitchen and pantry were flooded because the icemaker wouldn't shut off. My husband had to unplug the refrigerator to stop the water from pouring out
That is a rare happening but the solution is inside the ice maker itself. Click Here=>MSD2732GR Ice Maker Parts Break Down Part 13 is the Click Here=> 627985 Ice Maker Thermostat and sometimes it is just less expensive to replace the complete Ice Maker=> Ice Maker
Assembly
Simply unplug the ice maker from inside the freezer section rear wall until you can replace the part or ice maker. If you have more questions feel free to ask here or my through my web sites. Thanks, Sea Breezesea_breeze_15.jpg
Appliance 911
Dec 08, 2010 | Maytag MSD2732GR Side by Side Refrigerator
My refrig stop making ice after I changed the water filter. I had the filter out for about 3 hrs, would this cause the problem?
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 28, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
My icemaker just stopped making ice today....please help
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I woke up this morning to a flooded kitchen due to the ice maker, in my Amana refrigerator, not making ice and just pouring out water. What is the problem?
Either the switch in the ice maker is stuck keeping the valve open or the valve has stuck. Unplugging the frig will tell you which it is. If the water stops when the frig is unplugged it is the switch. If it does not then it is the valve.
Eric
Dec 12, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
May 02, 2009 | LG LRSC26925 Side by Side Refrigerator
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
GE Ice maker water flooding
Dear friend,
ngfam at you service! happy to assist!
Perhaps you should try service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Hotpoint HSS25GFP Side by Side...
Water "pouring" from freezer condenser
sounds like drain in freezer is clogged and has iced over
so when unit goes into defrost water leaks into freezer bottom and freezes
you can either shut off fridge for a day and let ice in drain melt
and hopefully clear line
or u can take back cover off freezer section pour hot water in drain pan and make sure drain hole is cleared and draining down to pan
Jun 21, 2008 | Sub-Zero 611 / O Bottom Freezer...
Refrigerators Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
