Question about Mitsubishi WS-55807 TV
Milky white screen
In the first 5 minutes of watching the screen will have a milky white haze that comes and goes on an interval of several minutes with it on and then Ok for several minutes.
  • 2 more comments
  • chriswerland Jun 18, 2008
    same thing is happening in intervals but it is also changing the tint of the screen
  • goodtymguy Jul 24, 2008
    my WS-55807 is turning the milky white on a regular basis now, as well as teh occasional yellow tint... any suggestions? is adjusting the voltage a viable option for a less than techsavy person or has this become a service call?
  • hopeless2 Dec 29, 2008
  • fivehopes Jan 18, 2009
    I have the same issue. The screen goes to a milky white. Please help
    Problem Solver:
  • 8 Answers
Adjust the screen voltage lower.
Posted on Jun 03, 2008
What would cause oil to turn milky white?
That is the typical color when water is mixing with the oil.
Probably a leaking seal or gasket.
The washer will need servicing.
May 05, 2014 | Simpson MegaShot 3100 PSI Gas Powered...
Briggs & Stratton 18 hp motor oil is milky white
The usual cause of milky white oil is water. It can come from a cooling system if so equipped or oil contaminated with water before it was added to the motor. It's possible to get water in the crank case from condensation or water getting the motor if it's left out in the rain but this usually results in small amounts of water that easily evaporate when the motor gets hot. Use a good motor flush and change your oil then watch it closely. If it gets white again you'll have to find out where the water is coming from.
Oct 01, 2012 | Measuring Tools & Sensors
Milky oil dipstick, white exhaust smoke, coolant in spark plugs
*White milky oil on dipstick = coolant in oil.
*Coolant on sparkplugs = cracked head or blown head gasket
*White smoke = burning excessive oil in the cylinders, which can be caused by a number of things including valve seals, cracked head or blown head gasket.
***All three of these symptoms together, however, means its the head or head gasket. Both are costly but better the head gasket than the entire head.
Jan 18, 2012 | 2002 Buick LeSabre
Oil milky white in pump
it may have a slow water leak inside the pump.
change oil and monitor the new oil.
if it goes milky the next time you use it then it has a bad leak and the seals will need to be
replaced,otherwise the bearings will rust & seize
Dec 18, 2010 | Honda Pressure Washer PSI 3000
I have a toro 421 snowblower i filled it up today with oil and gas when I started it a milky white oil looiking came out the breather tube what could have caused this
it sounds like you had water in the crank case.
Stop running it immediately and drain all the oil. Then make sure the crank case is empty of oil and clean, and refill with fresh oil. After you fill it back up with oil, run it a minute and check again for any milky/foamy oil. If it is clean, check it again after several minutes. If it stays clean, you should be good. If it is milky again, take it for professional service, as you probably have a damaged gasket somewhere.
Nov 16, 2010 | Toro Lawn Mower With Toro Power Tools
When loading the program, the main screen comes up but is a milky
Try and run the program in compatability mode, sounds like it may not be compatable with your OS.
Try Malwarebytes if you have no luck with webroot
Aug 01, 2010 | Webroot Spy Sweeper (spysweeper) for PC
Not cleaning and milky haze to dishes
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 10, 2010 | Whirlpool DP940PWSQ Free-Standing...
White milky substance in oil resevoir
no that is cause dby oil and coolant mixing together
Apr 29, 2010 | 2002 Mitsubishi Lancer
Smoke emitted from the engine area
If your oil is turning milky and smoke is coming from the engine check to see if your exhaust smoke is blowing white. If it is, you've got a blown head gasket. Hate to be the bearer of bad news, but good luck.
Jan 03, 2010 | 2002 Volkswagen Passat
Mitsubishi WS-55807 TV Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
