Question about Vtech 9009111 Cordless Phone
My vtech phone is not charging.should i buy a new battery?
Try to check ur charger,if its ok,then buy a new battery..
Posted on Oct 11, 2010
My Vtech IA5879 phine I installed a new battery and it has a battery icon in lower left corner of phone wiht and X thru it and charge light is flashing. It has been charging for a few hours. Is this...
some vtech phones put a chip in their phones and will not take an aftermarket battery...either that or its the wrong one for the phone...ive worked for a battery store for 3 years
May 04, 2011 | Vtech ia5879 Phone
One phone is not working.
The issue here in "most caases not all is the battery is at its prime" i would first buy a new battery let it charge for 20 hours!! then try reregistering the headset. if that does not work or reregister then you know now you got a bad transmitter radio inside. Try all reset methods as well even before you spend $12 bucks on a battery pack. Chances are its the battery, worse comes to worse the headset needs to be replaced.
thanks this was a FREE solution please do be considerate and rate and leave postive feedback thanks.
Apr 28, 2010 | Vtech Cordless 6041 Phone
After buying a new battery, the phone constantly says Needs Recharging after 2 weeks on the cradle
Take the battery back to the store and exchange it for another one, explain that the battery won't charge.
Or just buy another one.
Jul 21, 2009 | Vtech VT-IA5879 Phone
Vtech 2656 cordless phone battery not charging
You need to replace the battery pack. Wal-Mart, Best Buy, Circuit City and a few other stores may carry this battery. Just call them first so you don't make a wasted trip.
Mar 26, 2009 | Vtech V2656 Cordless Phone (vtechvt-v2656)
Charging light is blinking
Yes, your assumption is likely correct. A rechargeable battery thats life is up, will still show its charging indefinitely. However, I've also seen the same scenario with bad recharging base, even in high dollar units. I would recommend replacing the battery first, because that would be the least expensive option, and most likely to fix it.
Also, you can return the battery if that doesn't work.
If its the base, its probably cheaper to just buy a phone, unless you just happen to have a local place that does repairs on electronics, and they can do it cheaply. Likely, they'll tell you that its not cost effective to do a repair though.
Hope its just the battery.
Mar 20, 2009 | Vtech VT 1920c Cordless Phone (VT-1920C)
Replacement battery for VTECH IP 811 cordless dies fast
It seems like the phone uses a lot of power or you talk a lot on the phone. If your buying a cheap battery just remember you get what you pay for. This site here has some batterieshttp://www.shopping.com/xPO-Vtech-VTECH-V-TECH-Cordless-phone-battery-for-IP811-IP-811-NEW Otherwise check Ebay or Amazon. Hope I've shed some light on this for you. You might just wanna get a new phone.
Mar 18, 2009 | Vtech IP 811 Cordless Phone
Does not keep charge
Vtech 5.8 GHz does not keep the charge and
characters & numbers look choppy
Thank you
Jul 12, 2008 | Vtech 9009111 Cordless Phone
Low battery
You need to buy new batteries for your phones. Large retailers charge $10-12 per battery but you can usually find them for closer to $4 online at amazon.com or eBay.
Jun 22, 2008 | Vtech 9009111 Cordless Phone
Phones cant find base
I have two handsets, one of them recently starting dropping the connection to the base quite regularly [even if it was just inches away], and I ended-up in the same situation after unregistering the phone.
In my case, I was able to remove the battery from the phone [as you did] but also unplug the power on the base unit for several seconds. After restoring power to both, I was able to re-register the handset and it appears to be working more reliably now.
Jun 09, 2007 | Vtech i5871 Cordless Phone
Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Mar 20, 2007 | Vtech i5808 Cordless Expansion Handset
Vtech 9009111 Cordless Phone Logo
402 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
