Question about Toshiba Televison & Video
MY TV IS A TOSHIBA HM67 SERIES 50". IT WAS WORKING OK. AND SUDDENDLY JUST MADE A NOISE LIKE WHEN A LIGHT BULB BLOWS, AND AFTER THAT IT LOST THE SCREEN, AND TURNS ON/OFF BY ITSELF EVERY 3 SEC
  • 1,476 Answers
Ev ashley,
Your description is perfect. You need a new lamp. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will walk you through the process of changing the unit and also where to get the new parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 11, 2010
I have toshiba 50hm67 replaced lamp...tv worked, then quit working again, and giving blinking yellow lamp error light when turn on...after a few moments tv tries to turn off and back on
OK. I have this same issue. I replaced my bulb a month or so ago. TV worked fine. Then one morning I turned it on and it was on for a good while, till it went to a black screen w/ sound only. Lights were going through the reboot process as designed for 8 attempts before it went to the solid red light. From the red light, if I unplug and plug back in, the tv will come on for a given amount of time, which varies, and then cut to the black screen. A repairman told me that it sounds like the digital board is bad. He wanted $150 for the board and $100 labor. I cannot find anywhere where the board would be located or where I can purchase a replacement.
Jun 15, 2011 | Toshiba 50HM67 50" HDTV
I have a Toshiba TN50X81 Cinema Series HD the sounds works great but there's no picture. It just went blank all of the sudden. Opened it up and there's 3 bulbs and none of them are working. Can anyone...
the bulbs go out it is normal on projection tv's, you can order the new one online, just out in the model number of your tv and you will find it, be very carful not to touch the bulbs when they come or when you are putting them in the tv
Aug 11, 2010 | Toshiba TN50X81 50" Rear Projection...
Tv not working
Bulb may be bad or the lamp housing is damaged from heat. The plastic housing warps causing the micro switch that tells the tv the bulb is in goes out of alignment and the tv thinks the bulb has been removed
Aug 25, 2009 | Sony Grand WEGA KF50SX300 50" Television
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hln5065w dlp blows bulbs
The N series, needs to be told via service menu options, what type of bulb is being installed.
Jun 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Cleaning mirror and how to get in there
Hello timbick45,
You want to remove the top rear panel. Remove the screws and the top, along the sides, and along the middle of your TV (from the rear). Onec that is done be very careful because the mirroe is attached to the rear panel of the TV. set the back down and with a clean cloth and a can of air remove the dust off of the mirror, use a light window cleaner, after removing the dust. To clean the bulbs just use air to blow the dust off (not not attempt to clean the bulbs with any solvent.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technology-llc.com
Mar 30, 2009 | Toshiba 50H82 50" Rear Projection...
Humming noise in Toshiba television
my 46HM95 was humming also, I have the extended warranty and the company came out and diagnosed it as the light engine. the part was backordered and it was just fixed today, it was ordered back in February. Problem was solved.
Aug 12, 2008 | Toshiba 46HM95 46" HDTV
Television Problem
I have just run into the same thing, prior to the picture not coming on there was a loud whining noise, I thought it was the fan in the back, but, what I tried was removing the lower back panel, LIGHTLY tapping the light wheel assembly just left of the Bulb housing, and using a shop vac to first, **** the assembly around the edges and then reversing the air and Blowing it out. After much dust and dirt flying around the TV came on. It now only makes a little noise now and then, but, I will try this again today and then put the back panel back on. Since it would probably cost as much as a new TV for the color wheel, I gave this a try. For now, it is working.
Mr. Wizard
Jul 06, 2008 | Toshiba 62HM95 62" HDTV
Blinking power light
depend on how U use it and how long is recommended that after 4 hour es of use turn it of 5 to 10 minutes to let the lamp cool off no some laps use are between 7 to 9 thousand hour
Apr 03, 2008 | Toshiba 50H72 50" Rear Projection...
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
269 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
