Question about Intel Motherboard
Motherboard why is there no monitor socket on the motherboard itself??
    Scholar:
  • 187 Answers
Unfortunately not all boards have onboard graphics (the vast majority of the newer (last 3-4 years or so) do, but even then, there's still the odd one or two manufacturers that seem to think it'll be fun not to.
Posted on May 31, 2008
Display coming red in colour
Use the following steps to troubleshoot this problem:
  1. First try resetting the color settings using the following steps:
    1. Right-click on the desktop
    2. Choose Graphics Properties (or choose Graphics Options), and then Graphics Properties...
    3. Click on the Color Correction button (or click on the Color tab).
    4. Click Restore defaults.
  2. Next, check for a button or menu item on the monitor for adjusting the color balance. (See the monitor manual for more information.)
  3. Unplug the monitor from the computer and plug it back in again to assure the monitor is connected securely.
  4. Examine the monitor's VGA connector to make sure there are no bent or broken pins.
  5. If one is available, attach a different monitor to see if the problem goes away.
  6. Attach the monitor to a different computer to see if the problem is with the monitor itself.
  7. If the problem persists, the monitor may be damaged or defective.
Feb 16, 2013 | ASUS US M5A78LM LX Motherboard AMD Socket...
My d845gvsr motherboard is not working.I have checked the ram,processor,monitor and power supply. All of them are ok but my comeputer still showa a black screen.HEEEELLLLLLLPPPP MMMMEEEE PPLLLZZZZ!
Well, if all the other parts you have checked are indeed working, the only thing left is the motherboard itself. With only the processor, RAM and power supply connected, the board should start and the BIOS should run through POST. If it doesn't, you need a new motherboard.
Jan 23, 2011 | Intel D845GVSR Motherboard
I have a Satellite P35-S611 that will display fine on a external screen. I have tried three different screens on it that I know is good but no luck. the screen plug seems firm and looks to be good. Any...
Hi and welcome to FixYa!
As a first course of action I strongly suggest that you reinstall the motherboard driver. You may have a system crash on the graphic card that's why it won't work on external monitors.
If the problem still persists then there are two things to look at. First, the connection of the motherboard to the external monitor socket can be damaged or loose so you will have to use soldering gun and lead to attach it. If the motherboard and external monitor socket looks fine then the problem can be on the graphic card itself. This will sure need replacement for it to work.
Hope this helps and thank you for using FixYa! Have a good one!
Dec 01, 2010 | Computers & Internet
Hi i ive got a pc with msi ms7312 motherboard ,unknown what procesor but for sum reason when turned on my monitor wont *** on ,it has on bourd grafix ,iv tried the monitor on the pc im using now and it...
It's an very old Athlon XP processor. But the problem isn't with it, it's with the motherboard itself, the chipset has died.
There is nothing you can do, it's dead for good. Replace it - any Socket A motherboard with DDR memory will do.
Oct 18, 2010 | MSI KM4M-V Motherboard
Balance Computers
You could open up the PC, and see the model # of the motherboard, and search for drivers for it. Many boards are labeled between their expansion slots. Some are also near the CPU socket itself. Try not to touch the Motherboard if you do this!
Even a slight static discharge could injure your computer!
Jun 06, 2010 | Balance CM2017 17" Monitor
The system had blown the ATX 450w power supply and I replaced it. Upon boot the system went into login for 5 min then shut itself off and will not power up the monitor. CPU fan and heatsink were cleared of...
Try to put a separately vga card if you worked with the internal one from the motherboard. The atx may have blew it up.
And try to send the motherboard to warranty.
Feb 17, 2010 | PC Chips PCChips A13G+ v3.0 Motherboard -...
I have a Motherboard gigabyte GA-8PE800. when i
The ATX 12v ( 4 pin Connector ) is For The CPU Power.
This could Indicate, either A Faulty CPU.
Or a fault To The Motherboards ( BGA ) or CPU Socket Holder.
Or alternatively, The Actual PSU Itself is Faulty.
You can obtain A CPU Socket Tester from e-bay. And A PSU Tester.
Hope This Helps Mike @ Compurepair.
Oct 16, 2009 | Intel Motherboard
No monitor signal
have you tried checking the monitor to another computer? it could be the monitor?
if not, could be the graphics/video card, or even the motherboard itself could be faulty!
Jun 19, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
My monitor will not come on with my motherboard
have you connected the power cable to the processor socket? this is the small square 4 pin plug with 2 yellow and 2 black cables. If this is not conected the cpu itself will not be running even though everything else is, and thus no monitor. If this is not the problem, try reaseating the memory and also check for the baord "grounding" on the chassis.More help ? http://www.motherboardsrus.net and use the contact us button, Chris
Jun 07, 2009 | Foxconn |648FX7MF-S SIS648FX Motherboard
Intel Motherboard Logo
14 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
