Question about Dymo RhinoPro 5000 Thermal Label Printer
I have a little blue plastic clip with a slot in it and i'm not sure what it is used for as it fell out when i inserted tape.
    President:
  • 566 Answers
That will be the cleaning tool, used to clean the print head of your label printer.
It fell from the compartment lid where you should stick it when you are not using it. The slot is used to fasten it to the lid, so look for a salience in the back of the lid that can fit that slot and press it to fix it to the lid.
Posted on Oct 11, 2010
Broken prong at one end of safety interlock switch (plastic plate)must replace
Just in case someone comes across this in the future looking for an answer like I did. I jerry-rigged a solution to keep my Tech Solution TS-4500 going as I'm in the midst of a major shred job. Here's how I jerry-rigged a replacement pin for the flap:
1) I straightened a coated paperclip.
2) Wrapped the two ends together in duct tape, fitted to the size of the insert on the top of the shredder that the pin goes into.
3) Snipped off the excess paper clip at the opposite end of jerry-rigged pin, so there isn't more metal inside the shredder than necessary. (Leave enough to attach to the flap [See next step].)
4) Duct-taped the paperclip to the flap to keep it in the correct position.
5) Inserted the hard plastic pin into its slot and then the jerry-rigged pin into its slot.
The flap is able to swing up and down, and I've had no problems using the machine and the machine has had no problems knowing when it's full and auto-stopping.
Jul 07, 2014 | Tech Solution TS-4500 Shredder
The handle fell off the kettle, how can I re-fix it?
If it do not have any obvious way to fix it (locking clips or screws) and it was just inserted on the metal part ..than you can use some kind of glue for plastic and fix it back again .a super -glue will work or a strong plastic adhesive .Clean both ends so that any grease to be removed...and apply the adhesive on the plastic end .. and than insert it to the metal end ..in such a way that the adhesive to fill the space and the excess substance will drain off when you press them together. leave them to react for a while without touching them ..be sure you choose a temperature resistant adhesive ...
Nov 16, 2011 | Alessi Al384730-640 Cordless Electric...
My F4280 has blinking on light and blinking cartridge lights and the letter "E" in the Start Copy window, cannot scan or make copies but printer part works. Message in desktop says "Scanner Failure" but...
The product uses various combinations of flashing lights to indicate its current status.
  1. Turn off the product.
  2. Disconnect the power cord from the electrical outlet.
  3. Wait 60 seconds.
  4. Reconnect the power cord to the electrical outlet.
  5. Turn on the product
Issue
The Check cartridge light is blinking. Cause one
The cartridge door is open.
Solution one
Make sure that the cartridge door has been completely closed. Cause two
The cartridge is missing or not seated correctly.
Solution two
Insert the cartridge by sliding it forward into the slot correctly. Cause three
The tape was not removed from the cartridge.
Solution three
Make sure that the plastic tape has been removed before inserting the cartridge into its slot. Cause four
The cartridge is not intended for use in this product.
Issue
Solution one
Solution two
Solution three
Issue
Solution one
Solution two
Solution three
Issue
Solution one
Solution two
Solution three
Aug 06, 2010 | Office Equipment & Supplies
Hour-hand fell off clock
Plastic clock glasses are fitted on clocks in two different ways:
1) Clip-on plastic glass;
Check carefully all around the plastic glass and find where the clips are positioned. Insert the screwdriver between the glass and clock bezel and use the lever action to unclip it. Do the same to all clips following one by one till the glass come loose.
2) Glued plastic glasses;
Do exactly the same as described above, just this time go bit by bit all around the glass till it come loose.
NOTE: In both cases the plastic glass can crack if you are not expierenced in such an action! Start with ease and do not force that plastic glass too hard.
Rate me, please.
Mar 14, 2009 | Timex Watches
RESERVIOR FLOAT
The float goes into the bottom of the reservoir. If you look in, you'll see a little slot on the side down at the bottom. The float goes in so that the little tang at the bottom and pointed out.
You should have a metal clip that probably popped off. The clip clips onto the edge of the plastic in the reservoir that forms the slot for the float. The clip simply has to be pressed onto the plastic edge. The best way to do that is to get a stick and cut a notch in it. You might want to use some double stick tape so that you can put the clip onto the stick and then lower it into the reservoir and press it onto the edge of the plastic.
Oct 19, 2008 | Philips Senseo HD-7810 Coffee Maker
Sdio Wireless Lan Card Wlan 802.11b
The blank plastic is NOT to be used while other cards. I am assuming you are talking about the SD card slot on the side (black plastic filler) There should be no movement of the SD card when in place.
If you are talking about the CF card slot on the top of the Axim, again the blank plastic is a dust cover when no card is in place and is not used with cards inserted. There is a bit of open area on one side of the card. Carefull with the pins at the bottom and be sure to insert correctly. Again there should be no movement of the card once inserted fully.
Don't know what you are quoting from the manual. I still have mine and the only thing I see similar to your quote is to "align the tab on the back of the CF card with the notch in the CF slot.." This is to make sure you have the front and back correct and for removal of the card (by grasping the ridge/tab)
Jul 29, 2008 | Dell Axim X5 Pocket PC
Chabging the batterys on the prg 40
If you look very closely you will see that one side of the clip goes nearly under the battery. the plastic there has what looks like a small hole near the metal. It is in fact a slot. use a straight pin inserting it in the slot and gently moving the clip away from the battery. There is bend tension on the clip and it should raise slightly when released. Then use a tweezer grab the battery.
use your tweezer to hook the clip back over th plastic after you insert 4 new batteries.
Jul 01, 2008 | Casio PRG-40T-7 Pathfinder
Lexmark X3470 Printer Plastic clip (white)fell off
i pushed the little black trigger in and at the same time put a couple drops of crazy glue on it. works like new!!!!!
Mar 14, 2008 | Lexmark X3470 All-In-One InkJet Printer
Wire diagram for installation and where can i get the plastic inserts for the buttons
i just got the wiring for the sony xe-mk90II eq, heres a picture :
top right is the ground , bottom right is constant power, blue is the remote turn on. if you have a old wire harness around you can pull out the blue ,yellow, and black wires with the metal clip on and make than fit right where the wires should go. but make sure u rap the metal clips with electrical tape so the wires dont touch or you will fry it.
Feb 22, 2008 | Sony XE-90MKII 9-Band Car Equalizer
SHU 43 Built in-removed door, clips fell out
Those clips will fit into slots on each side of the door frame just above the hinges, Put them back into the frame, then install your new stainless panel. If they fall out b/4 you can get the panel back on, try taping them to the door frame with some masking tape to hold them in place while you secure the stainless panel.
good luck.
Feb 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dymo RhinoPro 5000 Thermal Label Printer Logo
73 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
